What does 241 casted on the heads mean?
My cylinder heads have the number 241 on them, what does this mean? Does this support my theory that I have a "freak"? Here, check out my very very very unexpected kill. https://ls1tech.com/threads/showflat...amp;PHPSESSID=
Re: What does 241 casted on the heads mean?
I also think people have been seeing higher stock flow numbers out of the 241 casting. (Better base for porting)
I believe JPR has spoken about it before.
cheers,
Chris
cheers,
Chris
out of May GMHTP
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12559853 (1997-98)
12559853 (1999-00) (not sure why same PN)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
Head: 2001 LS6 5.7 Litre Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Part Number:
12572035
Compression Ratio: 10:1
Head: GMPP C5R
Part Number:
12480005
Combustion Chamber Volume: 38cc
Compression Ratio:
Intake Port Volume:
Head: GMPP C5R
Part Number:
12480025
Compression Ratio:
Intake Port Volume:
Head: GMPP C5R
Part Number:
124800290
Combustion Chamber Volume: <30cc
Compression Ratio:
Intake Port Volume:
Casting Number 241
Part Number:
12559853 (1997-98)
12564241 (2001-03)
Casting Number 243
Part Number:
12564243
Casting Number 706
Part Number:
12559852
12561706
Casting Number 373
Material: Cast Iron
Part Number:
12561873
Casting Number 317
Part Number:
12572035
Head: GMPP C5R
Part Number:
12480005
Compression Ratio:
Intake Port Volume:
Head: GMPP C5R
Part Number:
12480025
Compression Ratio:
Intake Port Volume:
Head: GMPP C5R
Part Number:
124800290
Compression Ratio:
Intake Port Volume:
