Anyone swap a TR230/224 for a G5-X2 ?
Old 07-15-2003, 07:51 PM
offaxis's Avatar
Default Anyone swap a TR230/224 for a G5-X2 ?
Has anyone done a TR230/224 swap for G5-X2 ?
If so what kind of gains were seen ?
Im concidering this move now.
Jeremy
Old 07-15-2003, 09:28 PM
Geoff's Avatar
Default Re: Anyone swap a TR230/224 for a G5-X2 ?
We now have a cam in testing even bigger than the G5X2...the TR 236. Yes it will fit in a stock headed LS1 with no problems and has been engineered to make more power up to 7000 RPM than any other 'street' hydraulic LS1 cam currently available. And yes it is still a reverse split. More results will be posted soon.
Old 07-15-2003, 09:35 PM
needmoremoney's Avatar
Sounds close to my cam 228/236 .571 .602. If its bigger, will It still work with .005 shaved off my 5.3 SII heads?
Old 07-15-2003, 09:52 PM
Josh's Avatar
Perhaps this is a stupid question, but is the lift going to be as dramatic as that of the G5X-2's?
Josh
Old 07-15-2003, 09:58 PM
Geoff's Avatar
The cam is 236/230 .590/.570 so it is still a reverse split with an intake closing point the same as the TR 230. This cam is basically designed to have the same power band as the 230...just more of it. Heads that have been milled .005" should be fine.
Old 07-15-2003, 10:39 PM
Kens_02SS's Avatar
How will it work with stock heads and upgraded springs, retainers..etc? What could i do with it, with stock heads and a M6?
Old 07-16-2003, 12:56 AM
offaxis's Avatar
If ya need another test car let me know. Im currently making 421rwhp with the TR230/224 in my A4 car. This is my second TR cam in the car so far.Ive been very happy with the performance of the TR cams. Im just looking for another 10+ hp
Old 07-16-2003, 07:11 AM
Geoff's Avatar
This cam is primarily designed to work with stock heads. It will be fine with stock heads that have upgraded valvesprings.
Offaxis I will be in the shop this afternoon, give me a call.
Old 07-16-2003, 11:02 AM
Ragtop 99's Avatar
Geoff:
The TR 230 is (was) on a 111 LSA. To keep the same intake closing point are you going to a 110 LSA with another 2 degrees of advance?
BTW, Thanks for sharing your development work with us.
Old 07-16-2003, 12:42 PM
Josh's Avatar
Hey, I'd be happy to test it out as well!
(Worth a shot, anyway).
Josh
Old 07-16-2003, 05:16 PM
offaxis's Avatar
Hey Geoff
I tried to call a few times today . I left my name and # for you .
Thanks
Jeremy
Old 07-16-2003, 10:41 PM
gillbot's Avatar
What happeden to all the TR230 cams on the 110LSA? Mine is on a 110, but all the recent ones seem to be a 111, what is the reason for this?
Old 07-17-2003, 12:18 AM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
TR236!!!
Old 07-17-2003, 12:43 AM
Bowtieman4life's Avatar
Yeah but its a reverse split which is the best way to go with a fuel injected car.
Old 07-17-2003, 09:25 AM
KGSloan's Avatar
man, i can't wait to see how this cam does. i just put in my TR230 and love it. great work thunder
Old 07-17-2003, 09:39 AM
redz_02's Avatar
time for some heads
Old 07-17-2003, 10:24 AM
1fastWS6's Avatar
KGSloan: Who did your tuning for that cam (assuming you have a custom tune that is)? Have any sound clips?
Old 07-17-2003, 01:40 PM
KGSloan's Avatar
21st century muscle cars in dallas did the dyno tune for me. i would not hesitate to recomend them to anyone. i was very impressed with their shop and the way every aspect of their company was run. and it was cool to see some 427 twin turbo vettes. anyway, i'm done with my plug.
1fastws6, i don't have any sound clips of my setup, but it sounds pissed off. there are some clips of a tr230 with duals at ls1database. you might look there
Old 07-17-2003, 03:11 PM
DanZ28's Avatar
I thought they have always been built on a 111 LSA unless you specified different when ordering. The cam card probably reads different though like 110.xx, but normally pretty close to the 111 LSA...
Dan
Old 07-17-2003, 03:17 PM
DanZ28's Avatar
Geoff, is this cam available now? I'd be willing to pull my TR230 out and and install the TR236 cam right now, I don't have stock heads though, but I have valve reliefs!!
Have you guys considered doing a 236/236 or 230/236 cam??
Anyway, so has anyone switched from a TR230 to the G5X2 cam??
Dan
