Jesel Rocker Arms
The Bull
Re: Jesel Rocker Arms
I don't have experience with those, but the new adjustables are pretty cool.
http://www.derty.org/382SR/images/DSC01007.JPG
I got a set of YT's for $450 and didn't miss the lack of adjustability. If you order the right length pushrods, you shouldn't need to adjust them. Also, LS1 hydralic lifters are very forgiving on clearance. I wouldn't get the Jessels unless I was doing solid lifters. BTW, I have ZERO valve train noise with the YT's!
Yeah, I have a comment... I've got a set of them sitting in the back of my car that have never been installed. Yours for $450 to your door. The only reason I didn't use them is because I'm using Schubeck lifters, which are SUPER touchy regarding pushroad length... so I opted for a set of adjustable rockers instead.
I just checked my SDPC catalog again. It says these are SS type rockers and they are new affordable ADJUSTIBLE rockers!!! price is $699.99
Jessels are a premium race unit and have a very stable single pivot system for all eigth valves per side... Terras, have a two valve pivot system
the power gains are mostly small (3-5HP) and due to the roller tip that the factory rockers do not have...
the main reason to get replacement rockers is their strength and they are not as noisy as stock rockers with a big cam...
stockers tend to let go and dump their bearings in the engine....
Jesels will not fit under stock LS1 valve covers without completely gutting the baffling for the PCV system. I did this and was getting a LOT of oil in the intake until I did the LS6 PCV setup with an in-line filter.
For street and drag applications, Jesels are probably overkill. Cartek installed them on my C5R 427 because I was planning on doing track days at Road Atlanta.
