ls1 hot cam
Old 07-16-2003, 09:45 PM
cameroz282k's Avatar
Default ls1 hot cam
what kind of power is the hot cam making with stock heads also what do you guys think of 4.8 truck heads with 2.02/1.57 ported polished no decking due to high compression already with the hot cam and a 100 shot via TNT with the boltons i have now and 100 shot i make 440rwhp and 486 rwtq what sould i look for in gains
Old 07-17-2003, 06:21 AM
*Bad Trader*
BYBYC5's Avatar
Default Re: ls1 hot cam
hotcam and truck heads (should prolly mill.015) and a little n20 would be a killer street setup, the hotcam loves the bottle....the cam wont up you comprestion but might fill the cylnders a little better or worse(cam remember for the hotcam). i would recomend,
milled.015 truck heads
hotcam,n20 and tuning....
Old 07-17-2003, 09:04 AM
SSCamaro99_3's Avatar
A lot of guys are making 360+ rwhp on stock heads and all the bolt-ons with the Hotcam.
Old 07-17-2003, 09:42 AM
TaTommyWS6's Avatar
I'm getting dynoed tomorrow with the mods listed below (which includes gm's Hotcam)
Wish me luck
Tommy
Old 07-17-2003, 11:59 AM
Colonel's Avatar
When comparing numbers between cams, always keep in mind that some cars can dyno better than 370 RWHP with the stock cam and stock heads. My '02 dynoed 359, for example, and it's an A4.
Old 07-17-2003, 05:07 PM
thanx guys TATOMMYWS6 good luck with your dyno
BYBYC5 with milling the heads .015 i would not run it piston to valve clearnce also what kind of compression will i be at
COLONEL hey man i know exactly what you are talking about i dyno 340 with just boltons and not even all of them that was b4 the ls6 intake but i am MTI tuned by jason also BTW have you seen any numbers out of your car at MTI every time i go there i just drulll all over it so you may have to wash it when you get it back lol thanx guys
Old 07-17-2003, 05:28 PM
*Bad Trader*
BYBYC5's Avatar
heck no! hot cam you could go .060 and be safe,
i beleive .015 on truck heads(5.3) should yeild 11.1cr
Old 07-17-2003, 06:14 PM
im running the 4.8 heads so if i mill them .015 that should put me at 11.5 cr right
Old 07-18-2003, 12:08 PM
TaTommyWS6's Avatar
Well, I got my results and I am pleased. Too bad its so damn hot today! 83 Degrees while the test was done.
RWHP-365
RWTQ-372
I'm happy because I gained a lot of area under the curve which is more important than peak hp for me. (This is my daily driver) Here is a link to the dyno graph:
http://tatommy.com/dynoruns.htm
I have my old run before the cam and intake also on there for comparison.
Tommy
Old 07-18-2003, 01:16 PM
damn almost 40 to the rear wheels not bad for a the hot cam and ls6 intake i think this will be a good buy for me but now i have to put all my effort to getting a 12 bolt or some kind of rear end
Old 07-18-2003, 01:22 PM
TaTommyWS6's Avatar
Yeah, keep in mind I put down only 325rwhp before the cam and intake with much cooler weather. Had I dynoed now with those same conditions I probably would have picked up over 45rwhp with those two mods.
So the comparison is not perfect.
Good luck!
Tommy
Old 07-18-2003, 03:29 PM
Cool my Hotcam just went in last weekend. Now I need to go play.
Old 07-18-2003, 05:39 PM
Mike 01WS6's Avatar
It shouldn't matter the temp that day if those are corrected numbers. Are they corrected or not?
Old 07-18-2003, 07:11 PM
TaTommyWS6's Avatar
They are NOT corrected, that is exactly why I mentioned the temp...
Tommy
