Do you think I have what it takes for 450rwhp?
Old 03-09-2008, 07:06 PM
white99's Avatar
Default Do you think I have what it takes for 450rwhp?
what do you think I should expect with a tune?
Here is what I have:
LS6 intake
Livernois LS6 'Stage 2' 59cc heads - flow numbers below:
Lift Int. Exh.
.100 69.5 59
.200 151.5 114.5
.300 211.4 150.1
.400 265.5 180.4
.500 297.2 190.6
.550 307.6 205.8
.600 310.9 210.4
w/ pipe 245
GM MLS .51 head gaskets
Cam: 234/240 .599"/.610" 113 LSA
Diamond -2cc valve relief pistons
Compstair 6.125 rods
Stock crank
LS1 3.905 bore
Old 03-09-2008, 07:32 PM
SOMbitch's Avatar
Those heads flow better than advertised huh. I am thinking of going with those too as the low to mid #'s are very good for a GM casting and they don't hog out the intake runner but keep it around 220cc. To answer your question I think you will scare it but that 9" will eat up too much to get you there. A fast 90/90 would get you a little closer too. Good Luck!!!
Old 03-09-2008, 09:39 PM
98RedBird's Avatar
Highly doubt you'll hit 450. I think you're going to need the FAST
Old 03-10-2008, 10:33 AM
LivernoisMotorsports's Avatar
LS2 vehicles typically make 450-460 RWHP with these heads, our stage 2 232/232 .595/.595 114 cam, and LT's with a stock manifold. You may need a FAST manifold to reach this number with a stock bore LS1.
Regards,
Rick LeBlanc
Livernois Motorsports
Old 03-10-2008, 11:48 AM
ArklaTexan's Avatar
Numbers and Mods in My sig, I reached 480 with LS1 heads, cam, Fast
Old 03-10-2008, 12:00 PM
brad8266's Avatar
I think you should be over 450, if not it will be due to the intake.
Old 03-10-2008, 12:23 PM
white99's Avatar
I plan on getting a Fast intake and 90mm TB when I get extra cash. For now I will sit on the LS6 intake and hope for the best numbers. I'll keep you guys posted when it's all done
Old 03-10-2008, 02:53 PM
allthrotle's Avatar
I fell about 5hp short of the 450 mark but, Im still happy with the car. The mods are in my sig.
Old 03-10-2008, 03:46 PM
Cobra Huntter's Avatar
I would say that it could be done. i put down 420rwhp with my setup
Old 03-10-2008, 03:56 PM
2000 cam'n SS's Avatar
I would put you at about 430 to 440 RWHP with that set up and without the Fast...With the Fast i think you will be alot closer to your mark of 450.
Old 03-10-2008, 04:58 PM
Xtnct00WS6's Avatar
Based on my results...I'd put you at around 430 on a dynojet.
Old 03-10-2008, 06:34 PM
slow trap's Avatar
i agree, i'll say 430-440 now and with a ported 92/92 (if you get new since 90/90 is discontinued) 450-455, possibly 460. just guessing though.
Old 03-10-2008, 06:43 PM
FMX05's Avatar
Yeah your gonna need a 90/90 if you want to hit 450. I don't see it being a problem once you get that.
Old 03-11-2008, 01:14 PM
white99's Avatar
I thought so, for now it's the LS6. I should be close with the size of the cam I'm putting in. Flow numbers on the heads were better than the Stage 2 Patriot LS6 heads
Old 03-12-2008, 12:43 AM
Disturbed Bird's Avatar
you should be able to but you could have made that with cam only if you got a vindicator
Old 03-12-2008, 12:47 AM
white99's Avatar
Wanted at least a little drivability..
Old 03-14-2008, 08:21 AM
88ls1blazer's Avatar
I have ran that head personally (but on a 64cc chamber) and a smaller cam. I think you will be quite pleased
Old 03-20-2008, 05:06 PM
white99's Avatar
Thats what I like to hear
Old 03-20-2008, 05:13 PM
jed.only's Avatar
do i think you'll hit 450 to the tires with this:
LS6 intake
Lift Int. Exh.
.100 69.5 59
.200 151.5 114.5
.300 211.4 150.1
.400 265.5 180.4
.500 297.2 190.6
.550 307.6 205.8
.600 310.9 210.4
w/ pipe 245
Stock crank
LS1 3.905 bore
no.
Old 03-22-2008, 09:04 PM
rarelyseen's Avatar
so you going to have jeremy help you with the motor swap? and when its done you want to run again?
