View Poll Results: Which Cam would be best all around between these two??
MS3 237/242dur .603/.609lift 112LSA
10
66.67%
SI6 235/240dur .621/.609lift 111LSA
3
20.00%
OTHER: Post your choice
2
13.33%
Voters: 15. You may not vote on this poll
MS3 and LS1SPEED GUYS CHIME IN.....
Old 03-17-2008, 01:54 PM
fastvet's Avatar
Question MS3 and LS1SPEED GUYS CHIME IN.....
O.K., I am trying to find out which is the best all around cam on performance between these two. The MS3 from Texas Speed or the SI6 from LS1 Speed cam? I am trying to stay in the mid to high 23X range and will be using the cam for street/strip use. It will be on a somewhat daily driver. Here are the specs for the debate:
MS3 ------------- SI6
237/242DUR ------ 235/240DUR
.603/.609LIFT --- .621/.609LIFT
112LSA ---------- 111LSA
Chime in guys!
Old 03-17-2008, 02:01 PM
ls1leadfoot's Avatar
the ms3 will be the better for daily use.....but the s16 cam will definatly sound better haha
depends on what you are going for
good luck
Old 03-17-2008, 02:03 PM
TXZ28LS1's Avatar
i would say the MS3 just cuz its more popular. never really seen much people run the SI6.
Old 03-17-2008, 04:31 PM
wfoz28's Avatar
Had the MS3 on a 111 LSA before the T rex and I liked it. So between the two I vote MS3.
Old 03-17-2008, 04:43 PM
kistlerjm9's Avatar
plenty of 11sec dd tr230's around, will pull from any rpm. sounds freaking ridic too.
Old 03-17-2008, 05:01 PM
conde'strans's Avatar
I'll be purchasing the MS3 myself so u know which one I voted for! I was between that one n the F13 but decided on the MS3!
Old 03-17-2008, 05:02 PM
fastvet's Avatar
So do you all think these cams match up since the SI6 is a 111LSA and the MS3 has a 2degree duration diferrence? LS1SPEED, you guys need to chime in....
Old 03-17-2008, 05:48 PM
Top Fuel's Avatar
How about a Top Fuel custom? 236/241 .612/.609 111.5 LSA
Old 03-17-2008, 06:09 PM
99WS7's Avatar
MS3 dumdumdum...have had mine in my ride for about 1 1/2 years and though I dont always DD my TA I have at times and overall its a good cam.
Old 03-17-2008, 06:34 PM
LS1SpeedAddict's Avatar
My MS3 has been great to me, no regrets.
Old 03-18-2008, 07:48 AM
fastvet's Avatar
That looks pretty good. Where did you pull those numbers from?
Old 03-18-2008, 03:08 PM
fastvet's Avatar
...bump
Old 03-18-2008, 05:15 PM
stealth355tpi's Avatar
im going to have to say MS3. no problem here, cant wait to throw some spray at it.
Old 03-18-2008, 09:52 PM
Top Fuel's Avatar
I just split the difference between the 2 cams specs that you posted
My bad. IMO though both these cams have 15.5* overlap on comp lobes, they are going to drive and perform damn near identical. I say go with the speed cam. theres too many MS3's running around this board as there is. I have a speed cam and its working. Either way you're going to get a good cam.
Old 03-19-2008, 12:24 AM
fastvet's Avatar
^thanks bud, thats what I was thinking! Granted, I am from Texas, I just need something people around here dont have. I am not trying to be a biter, if you know what I mean. I will let you know how it turns out!
Old 03-19-2008, 02:45 PM
fastvet's Avatar
bump...
Old 09-30-2008, 12:42 AM
Tom@SpeedInc's Avatar
Default SI6 cam results
Cam only 2002 Z28 M6, headers, lid and SI6
I checked pistons to valve clearance with SI6 cam .070" Intake .100" Exhaust, with stock 241 heads and MLS gakset.
Add AFR or Trick Flow heads, and the results follow.
