LS1 push rods question
I am getting ready to do a heads and cam swap and have new chrome moly ones for then but and just wondering. I don't think I am hearing a push rod knock but and not sure yet. I hit the rev limiter pretty hard this past weekend at the track. The car is running pretty crappy but is showing some codes now that point to something else.
LS1TECH & Trucks Sponsor
You very well could have bent a pushrod, or broken a valve spring. Both are common issues. Are you getting a misfire code?
Did you just miss a shift or did you do the 2-3-2 shift?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
I am getting a misfire in multi cylinders with a lean in banks 1 and 2 code. The car has a TH350 with a manual valve body. The shift from 1st to 2nd was a little late and it hit the rev limiter and about shut the car off. It was pretty hard, I have never done that before. But the car was already running crappy and it didn't get any worst after that happened.
Well I can't be 100% sure that it was not a push rod but today I changed the old TR6 plugs out and put some new TR5's in and new Holly 8mm wires and the car seems to be running great.
Well after a couple of days the car started having the multi cylinder misfire code again. I hook it up to the laptop and took it out for a ride. It showed misfires in all cylinder but mostly in number 3. I can now hear a weird sound from the top side of the motor like a valve train problem. I do now think I broke a Pushrod and most likely number 3 or a spring. I am gonna tear the valve covers off tomorrow or Thursday and pull the old Pushrods and replace them with Chrome Moly hardened Pushrods.
That's a good idea. Inspect your valve springs while you are in there especially if you don't find any bent pushrods, sometimes one can be broken but hard to spot.
__________________
Well I pulled the valve covers off to find no broken springs or any bent pushrods. I went ahead and replaced the push rods with the new ones. The car doesn't seem to run much different, but I will hook it up to the computer Thursday after I get off work and see if the misfires have gotten any better. Anyone else have any more input as to what else could be going on here.
