hitting rev limiter..any damage?
Old 07-25-2003, 12:12 PM
CuriousJa's Avatar
Default hitting rev limiter..any damage?
ive hit the rev limiter a few time in my '01 vette, everytime i hit it i let off the throttle right away, so do you think i have any damage and how would i know if i did any damage. the cars not making any new noises or anything. Thanks- Ja
Old 07-25-2003, 01:00 PM
2001CamaroGuy's Avatar
Default Re: hitting rev limiter..any damage?
your probubly good.....
hitting the rev limiter does not "usually" cause problems because GM sets it at least 200 RPM under where valve float starts to get bad.....
Old 07-25-2003, 01:56 PM
Restricted User
CAT3's Avatar
Although it is all case specific, it shouldnt be hurt any. Hell, I laid on my RL two weeks ago...sounded like a virgin import-drag racer doing miss shift for about 4seconds...of course I cringed while trying to get my foot off the throttle (kinda got it stuck-oops).
Old 07-25-2003, 02:00 PM
MEAN LT1's Avatar
Heh, check them pushrods, ls1's arent exactly known for strong pushrods. Id check them just to be on the safe side.
Old 07-25-2003, 02:19 PM
TaTommyWS6's Avatar
The rev limiter is there for the sole purpose of protecting your engine from damage. Don't worry about it.....
Tommy
PS If you misshift, then worry....
Old 07-25-2003, 03:35 PM
Camaroholic's Avatar
Or launching at the dragstrip.
-Andrew
Old 07-25-2003, 03:37 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
If you tap it a little it's not a big deal.
If you do a 3 to 2 missshift and the motor is tapping afterwards you might have some bent pushrods.
Old 07-25-2003, 04:28 PM
CuriousJa's Avatar
well its a M6 and what happened was once in awhile ill wind it out to far and hit the limiter but i immediately back off the throttle when that happens, its not like i "bounce" off it several times in a row, just once and i back right out of it, its just that ive hit it a few times of different occasions. -Ja
Old 07-25-2003, 06:00 PM
Colonel's Avatar
The rev limit is set really on the safe side. Don't worry. You haven't hurt a thing. I've been on the rev limiter hundreds...maybe thousands, actually ...of times and I've never hurt anything by doing so.
Old 07-25-2003, 09:44 PM
mcflyz28's Avatar
Someone actually said check the pushrods from hitting the rev limiter, that guy has too much time on his hands.Or I need to yank mine apart and check them a few times a week !
Old 07-25-2003, 10:53 PM
Jabroni's Avatar
As long as this was not a mechanical overrev, you should be fine. Listen for strange noises in the near future and take appropriate action. I wouldn't worry too much right now.
Old 07-26-2003, 12:23 AM
50ETR's Avatar
Hmmm
Old 07-26-2003, 12:32 AM
pimpmaro's Avatar
I've barely tapped the rev limiter a time or two and we just pulled off the valve covers and I do have a bent pushrod or two. Nothing too serious, maybe a couple of mm or so but I am changing them all out. I definitely had the tapping noise though. If you hear anything like that, it's easy enough to pull the covers off to at least check the pushrods. You might even want to do it to be on the safe side.
Old 07-26-2003, 07:36 AM
NB99Z's Avatar
I had mine set at 6400 and have hit it many times. Pulled it apart last week and all the push rod were fine.
Quick Reply: hitting rev limiter..any damage?
