Moisture under the oil cap
Old 03-28-2008, 08:29 AM
blu1's Avatar
Default Moisture under the oil cap
Now I know this can be symptoms of a couple things, blown HG but Im just not sold on that as the car only sees really short trips every day 6 miles one way.
Any ideas? The car is acting really normal Im just curious to others thoughts on this. What else could be causing moisture to build up under the oil cap.
The car is a H/C/I C5 for those wondering.
Thanks,
Matt
Old 03-28-2008, 08:33 AM
smokinponcho73's Avatar
they say its from codinsation inside the engine and to make sure you properly let your car warm up before each drive
Old 03-28-2008, 08:41 AM
99ssleeper's Avatar
It's normal. I went 2 miles to get some oil one day and when I popped the oil cap off it had the same stuff on the underside. I've never seen it after the vehicle is fully warm.
Old 03-28-2008, 09:08 AM
ls1leadfoot's Avatar
i have seen that and always wondered what that was.......on some cars it's really thick.....my d/d has it every once and a while....but i dont really take care of it like the dumdumdumdum....
Old 03-28-2008, 09:19 AM
GuitsBoy's Avatar
That foam and moisture is very common when a car see mostly short trips. Take her out on a nice hour long cruise and see if it goes away. When you only drive short trips the oil never reaches a hot enough temp to boil out all the moisture.
Old 03-28-2008, 09:20 AM
dodges and mitsu's oil caps look like a butter tub because of that and their poor design quality
Old 03-28-2008, 09:23 AM
DanZ28's Avatar
Have you modified the PCV system at all?
Old 03-28-2008, 09:35 AM
blu1's Avatar
The car will be seeing around a 60 mile drive tomorrow. I will check it when I get to the destination to see what its looking like. Thanks for the responses.
Matt
Old 03-28-2008, 01:44 PM
keep us posted.....good luck
Old 04-02-2008, 07:55 AM
blu1's Avatar
went for a longer drive and checked it upon arrival and it was dry as a bone.
Old 04-02-2008, 08:17 AM
GuitsBoy's Avatar
Good to hear.
Old 04-02-2008, 08:29 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Thats some country crock right there.....
(imagine that was butter......)
Quick Reply: Moisture under the oil cap
