Oil burn
Old 04-08-2008, 10:29 AM
smokintiresz28's Avatar
Unhappy Oil burn
Is it normal for a 60k stock ls1 to burn oil and I live in texas were the humidity is always 80% or higher is it smoking or is it condinsation ,also ive been using mobil 1 10\30 ive looked for the german castrol because i heard it would slow oil burn but cant find .
Old 04-08-2008, 10:38 AM
03Sssnake's Avatar
These cars consume oil for a number of reasons, the most common being the PCV system. The updated PCV valve would be the first thing I try, then a catch can. Before you do that, take your lid, MAF and air bridge off, you should have access to the Throttle-Body, open the blade and check the back of the blade. If its wet with oil your are aspirating oil via you PCV system.
Old 04-08-2008, 10:40 AM
03Sssnake's Avatar
Updated PCV valve
12572717 - PCV VALVE
Are you actually losing oil? Has the low oil light ever lit up, and or are you monitoring it on the dipstick? I just re-read your post. You are going to have some condensation in the exhaust with this humidity, that is normal.
Old 04-08-2008, 12:24 PM
Never had low oil light just change oil light which is oil life system, just put new pcv valve on about 2 months ago, i believe there is a biuld up on the throttle body flap on the inside. is it true about changing oil could stop the loss and if i remember correctly i never had this problem when i was running val 10\30 conventional.
Old 04-08-2008, 01:57 PM
SOMbitch's Avatar
Changing oil will make no difference. Something is causing it to burn and you need to get at the root of the problem. If it is not sucking in your intake a leakdown test can help you pinpoint (valvetrain or bottom end) your problem.
Old 04-08-2008, 09:07 PM
I dont know that i will consider major bottom end or valve train being the problem with only 60k that are not hard core miles.
