Cam Pro's, help me Spec a new cam for me
Well as many may have read i had some engine problems so i am doing a rebuild on my engine.I plan on Swapping cams out while i am into the motor also.So if you guys Could help me or Suggest a cam or even a Off the shelf cam for my needs i will be Very Thank full. Car is daily Driven with track visits often.I had the Tqv2 but i was not happy with the idle, i would like to have alot more aggressive idle .with a occasional street Romp from a dig or low Speed roll.I would love to have in the range of 400-420 rwhp
This is my setup i will have. Mind you i am on a Smaller budget than most.
1998 ls1 block
Forged Pistons and Rings
Stock crankshaft and rods with Arp bolts
Lt headers and xpipe
Bbk ssi intake ,I will switch to a fast after Engine Broke in and Tuned.
4.10 gears
Ported oil pump
Comp lifters
prc dual springs
hardened pushrods 7.4 -if i can reuse them
ported Tb
Built 6 Speed and stage 2 clutch
Stage 1.0 heads or 1.5 5.3 heads i have not Fully Decided yet .
1998 ls1 block
4.10 gears
Ported oil pump
Comp lifters
prc dual springs
ported Tb
I went through the same trouble looking for a good cam but decided on a pat g custom grind here is my thread with the info
https://ls1tech.com/forums/showthrea...369&highlight=
nope not yet but with a 110lsa and an electric cutout its going to sound nasty
and i can just close the cutout and have it go through my quiet slp dual/dual when i dont want to be loud
I do not Remember the Name of the pistons.I will be getting them from my Shop .The company that Carries them is PBM.But they are Forged with Rings for a very good price.
Someone could prolly spec you a a low 240s medium lift on a 110lsa that would sound nasty. Just make sure you have a fantastic tuner if your car is the daily grindmobile. That 110lsa has a real good chop if thats what your into.
yes i do want a more aggressive idle than i previously had with the 232 234,My tuner is one of the best in ky and goes by the name of BLUECAT.He is the Top tuner on Kyhorsepower.
