What is the part number for the ls6 coolant crossover lines?
I am going to install a fast intake and need the cross over lines to do it. Does any one have the part # for these?
Location: Your girl's back door giving her the long stroke while you're at work
Texas Speed has what you need if you don't want to hit up the stealership
http://www.texas-speed.com/shop/item...d=242&catid=12
You can cut the line where it heads to the back of the valley cover. then weld/solder it to seal it. You only need to have the coolant circulating from the front of the heads to the radiator. for the back, cut the lines right at the plug and seal them the same way.
If you want the GM parts we have them:
http://www.thunderracing.com/catalog...vid=3&pcid=177
20-12602540 GM Coolant Plug - Used when converting from LS1 style intake to LS6 or LSX style intake. (2 required) $5.29
20-12602544 GM Coolant Crossover Pipe - Used when converting from LS1 style intake to LS6 or LSX style intake.$35.50
Thanks,
Shane
Thanks,
Shane
All parts needed to convert to the LS6 style coolant crossover tube:
12551933 - Coolant Seals, Head: 4 each required
12602540 - Coolant Air Bleed Plug, rear: 2 each required
12602544 - Coolant crossover pipe, LS6: 1 each required
11517591 - Rear Coolant plug bolts (M6 x 1.0 x 30mm): 2 each required
