918 Titatium retainer weight verses factory steel
Old 08-06-2003, 07:43 AM
Larry's Avatar
Default 918 Titatium retainer weight verses factory steel
I weighed a set of Comp Cams Titatium retainers for use with Comp Cams 26918 "918" springs. They weigh 110-112 grains. My factory retainers weigh 170-175 grains. That's over 50% weight savings.
Old 08-06-2003, 08:00 AM
Dave Carney's Avatar
Default Re: 918 Titatium retainer weight verses factory steel
Yes, it is significant. I wasn't going to do them but then decided to go ahead in order to offset some of the extra weight I have from larger valves. Couldn't hurt for sure. It's more like 35% less weight though.....
Old 08-06-2003, 09:45 AM
Mike K.'s Avatar
Wow that is alot lighter.
Old 08-06-2003, 09:52 AM
2002 Trans Am's Avatar
Wow you guys are hard core!!!!
I still have my back seats in
Old 08-06-2003, 10:01 AM
Larry's Avatar
I don't know what the weight difference of steel verses Titatium, perhaps 35%, but these 918 retainers are machined differently than the factory steel so design is probably playing a factor here in the over 50% reduction.
My gram scale is very accurate. It has to be as it's a powder measure scale for reloading ammunition. They have to be pretty accurate to avoid accidents.
The reason I put a range is because the retainers weigh differently one to the next.
Old 08-06-2003, 10:23 AM
2xLS1's Avatar
I weighed a Comp titanium retainer VS a stock retainer on a tripple beam scale and came up with titanium, 9 grams, stock, 11 grams.
Old 08-06-2003, 10:29 AM
Larry's Avatar
Whoops, I mean grains! I'll go correct that.
Old 08-06-2003, 10:50 AM
Fireball's Avatar
I weighed a set of Comp Cams Titatium retainers for use with Comp Cams 26918 "918" springs. They weigh 110-112 grains. My factory retainers weight 170-175 grains. That's over 50% weight savings.
thats 4.1 grams difference then (using 1 grain = 0.06479891 grams)
that equates to a total of .145 lbs reduction
Old 08-06-2003, 11:27 AM
Just to clarify, valve train weight is important in that it determines at what point/rpm your valves float, how stiff of a valve spring you have to run, and consequently how hard your valve smacks the seat and how fast your bearings wear..... I don't think anyone is buying titanium retainers to save on race weight
Larry, show me your math...(on how you get 50%) If the weight savings was half, then a titanium retainer would weigh half as much as a steel one. Alternatively, you could say, that a steel retainer weighs 50% more than a titanium retainer..
Old 08-06-2003, 12:37 PM
Larry's Avatar
Dang me! I divided with the wrong weight. I used 112 verses 170. About 35% is correct. Should have double checked my division when you first posted.
Old 08-07-2003, 07:09 PM
TexassTA's Avatar
I use chrome moly retainers with my 918`s.They probably slow me down about a billionth of a sec.in the 1/4 mile.They cost about $60
Old 08-07-2003, 08:15 PM
MyLS1Hauls's Avatar
I'd like to see the weight of the chrome moly ones to see how much lighter they are than stock.
Old 08-07-2003, 08:49 PM
CamaroSS_2002's Avatar
I've got chrome-moly ones. I'd like to know how much they weigh as well... someone weigh them please!
