Another "how much RWHP should this make" thread...
Just curious to what everyone thinks this combo will make on my 98 Formula WS6;
PRC stage 2.5 5.3 heads
MS3 cam (cut on a 112 LSA)
FAST 92mm intake
92mm TB
SVO 42# injectors
255 lph fuel pump
SLP lid with K&N filter
SLP crank pulley
ARH 1 3/4 LT headers
ARH ORY
Magnaflow catback
Car is a 6-speed with the stock 3.42's in it. Mileage is at 96,000.
The remaining parts are currently on the way, and with any luck everything should be done in 2 weeks. Hopefully I can get it tuned right after the install is done to show the exact results.
RWHP guesses?
FAST 92mm intake
92mm TB
SVO 42# injectors
255 lph fuel pump
SLP crank pulley
ARH ORY
Magnaflow catback
RWHP guesses?
Wow, you guys are guessing a lot lower than I hope to be. Perhaps all these other guys with pretty much this same combo are just seeing rare numbers;
462 RWHP- https://ls1tech.com/forums/showthrea...hlight=2.5+5.3
459 RWHP- https://ls1tech.com/forums/showthrea...hlight=5.3+ms3
461 RWHP- https://ls1tech.com/forums/showthrea...hlight=2.5+5.3
462 RWHP- https://ls1tech.com/forums/showthrea...294&highlight=
Not to mention this is the same setup Jon from TSP has on his car that did 475 RWHP (given that was probably ideal dyno conditions at sea level)
