freeze plug on head/block?
Old 08-11-2003, 11:03 PM
WicketMike's Avatar
Default freeze plug on head/block?
Hey guys,
I have coolant coming out between the #1 and #3 plugs, just below them, cant really see from where though. Is there a freeze plug it might be coming out of on the block or the heads?
Old 08-12-2003, 09:25 AM
WicketMike's Avatar
Default Re: freeze plug on head/block?
ttt
Old 08-12-2003, 10:45 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,100 Likes on 722 Posts
Right near #1 there is a coolant temp sensor does that help at all?
Old 08-12-2003, 04:51 PM
WicketMike's Avatar
hopefully thats all it is
im getting it looked at thursday
Old 08-13-2003, 01:44 PM
WicketMike's Avatar
i tried getting a better look at it last night and couldnt see much of where its coming from.
i see a sensor to the left of the #1 plug and thats not where the leaks coming from.
its leaking between the #1 and #3 below the headers
Old 08-13-2003, 03:20 PM
WICKED SS's Avatar
I had the same thing happen last night, we forgot to put that plug (freeze plug I think) that goes on the head on the passanger side in the back. Only thing now is I need to find out what size allen head will fit that? What side is it coming from?
Old 08-13-2003, 03:42 PM
WicketMike's Avatar
its on the driver side
Old 08-13-2003, 03:51 PM
I can shift faster than you.
Jason99T/A's Avatar
Did you recently change the heads out?
Old 08-14-2003, 06:20 PM
WicketMike's Avatar
it was the cooler line fitting, it wasnt screwed in all the way
whew!
thanks
Quick Reply: freeze plug on head/block?
