ls6 + tb??
the 97-02 LS1s used cable and the newer ones used drive by wire. The LS6's used a drive by wire throttlebody. The size is the same however, which is 78mm i believe and is all a LS6 will correctly accept. Unless you buy a BBK setup which has a plate to run a 80 or 85mm.
wow cool is that for sale?? lemme know
if i did put an ls6 throttle body on my 99 z28 with an ls6 intake what would i have to change? the linkage or anything? can it use the same fuel rails?
Thanks!
Thanks!
i just bought a used LS6 for $275
the p/n is
12573572
is that any good? does it have an egr? guy said it came off a trans am? but i googled it and i think it came from a Z06
any info on this specific manifold? like problems? common issues?
the p/n is
12573572
It's an LS1. Here's a list I compiled last year.
Stock 2001-2002 F-body LS6 is 12561184.
The Z06 LS6 is 12573572.
The old LS1 intake with the EGR setup is 12560688.
97-00 vette LS1 part # is 12556333
I believe that the F-body manifold is preferred and flows a little better than the Z06.
I dont think there are any issues, its just the EGR thing at this point for you. If your car is equiped the intake isnt you need to get rid of it from your car or modify the intake.
ok so i have a stock 99 z28 ls1 im putting in an LS6 p/n 12573572
am i gna need an egr block off plate? does that specific manifold have it? i wanna do be able to put it all together this weekend but dont wana get stuck and have to order a part. its my daily driver.. i also heard something about the cooling lines being in the way?
thanks!
thanks!
