oh so i want to take my motor out
Old 06-22-2008, 10:25 PM
Formerly darynC-10/23/10
Daryn's Avatar
Default oh so i want to take my motor out
is it possible that i can do this with just 4 big jackstands and a jack?.. or do i need a lift?..orrrrr is it possible to take it out the top?
Old 06-22-2008, 10:29 PM
LS1_K1DD's Avatar
If im not mistaken you can take it out of the top with a cherry picker. But you have to disassemble most of the motor before pulling.
Old 06-22-2008, 10:32 PM
Randy WS6's Avatar
I pull my motor from the top and had to remove the intake ,water pump and damper.Then it came out with plenty of clearance
Old 06-22-2008, 10:36 PM
ProjectDuStU's Avatar
me too..
Old 06-22-2008, 10:55 PM
frito1's Avatar
If you have access to a lift, is it easier to drop the suspension, engine and tranny out together and lift the body/chassis up?
Old 06-22-2008, 10:57 PM
Daryn's Avatar
i do not have access to alift , but i do have a cherry picker
Old 06-22-2008, 10:58 PM
slp--firehawk's Avatar
I took my engine out the bottom with just a POS jack and two jackstands not saying its easy but you know, bottom line its back in and it runs awesome.
Old 06-22-2008, 11:01 PM
frito1's Avatar
ok, I was just asking the question while we are on the topic for my own info
Old 06-22-2008, 11:02 PM
skeels's Avatar
I also dropped mine and put it in thru the bottom with 2 jackstands, a jack, and a **** load of wood. I wouldnt think of doing it thru the top. I also did all this on grass, not even pavement. Needless to say it wasnt THAT bad.
Old 06-23-2008, 08:24 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I took mine out from the top also
Old 06-23-2008, 08:32 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Ive always done top end removal. IF using a lift, unless you removed the motor from the suspension and then re bolt it in, you cant roll the car off and your tying up a lift.
Old 06-23-2008, 05:52 PM
Daryn's Avatar
yes , reason i want to do the top method , is simply becuase the car has to be movable ,
