help! cost to finish H/c
ok, i need to figure out how much its going to cost to finish my h/c and bolt ons....the motor is an 02 with about 40k on it.
here is what i have...
ported dart 225cc heads w/ valves only
fast 90 intake
fast fuel rails
Nick williams throttle body
long tube headers
need....
f14 high lift cam
custom y pipe
clutch (any suggestions?)
timing chain
pushrods
gaskets
lifters
injectors
tune
can anyone give me some prices on a couple things? like the clutch? and let me know if i forgot something???
ive got some money saved up and was wondering how much ill need.
thanks!!
fast 90 intake
fast fuel rails
long tube headers
need....
f14 high lift cam
custom y pipe
timing chain
pushrods
gaskets
lifters
injectors
tune
thanks!!
LS1Tech Premium Sponsor
I dont think it will be to terrible getting that thing wrapped up. Here's some of our prices:
Cam $370 on special
pushrods bout $110
Mail Tune From TSP $175
LS7 Lifters $125
Our Y Pipe Is about $130, but it depends on the headers
HC Complete Gasket kit is about $150.
Cam $370 on special
pushrods bout $110
LS7 Lifters $125
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I listed the typical minimum to much better quality is why it looks dramatic.
Really it isnt that bad depending on yoiur choices.
My custom ground Comp cam is always 370, pushrods 125.. $15 isnt a big deal
lifters $125 for ls7 or going up the scale to a better lifter the Morel. Heavy spring pressure and hi rpms, might want the added insurance of the Morel you might not. Personal choice.
Timing chain setup like $89 if that from SDPC
Injectors, pm me for info on them, $215 delivered for 30# SVO's
Gasket set SDPC as well have it shipped in the same box or TSP I suppose , look for the timing set. iirc n-motion at sdpc was the good deal
there are some little things and they add up but overall it isnt to expensive.
Check out Vince at Trifecta for mail order tuning he has a handheld that he sends out to you instead of having your pc sent to him. Very nice solution for those who dont want their car to be down for a few days using the traditional mail order.
Thats around 629 listed right there, figure maybe another 100 for fluids the car fluids for you a sanwich maybe and some bandaids..lol
Well a load bearing dyno is a great tuning tool. Best bet is to call Vince at Trifecta and let him explain how it works.
http://www.trifectaperformance.com/
30#svo's should be sufficent for a h/c 346
