Solid Roler Questions
Old 07-01-2008, 11:55 AM
shaulinmathvader's Avatar
Default Solid Roler Questions
I am thinking of building a 383 with a custome Hyd roller cam probably in the .640 lift and 250 duration at .050 range. My machinist wants to go solid roller.
I have already the non-adjustable yella terras that I used on a Trex. I know I havbe to buy adjustable rockers, but My question is is it worth it to go solid roller. How much gains would I see. Just trying to find out if spending more money is worth it.
Old 07-01-2008, 12:32 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
The solid roller is there for valvetrain control and stability, all depends on how hight you plan to spin the motor. With a solid setup you are going to need a few more things, solid Lifters, restricted pushrods, taller valve covers, and the ability to adjust and set your own lash just to name a few.
In a properly matched setup a hyraulic lifter can handle that cam without a problem. But Mismatched components like heavy valves, heavy rockers and stiff springs you will start killing lifters.
Old 07-01-2008, 03:08 PM
If i stay hyd roller, What lifters should I use. I Have only ever used the stock and those always held good for me but now I don't know what lifters to get if any.
Old 07-01-2008, 03:15 PM
aNuBiS's Avatar
Crane says on their website, and ive seen on paper a solid 10-15hp gain in the upper RPM range. Is this worth the time/money invested? Thats up to you...
Old 07-01-2008, 03:21 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
depending on your budget you could get the Morrel Hydraulics, GM caddy racing lifters, or Stock replacements. In a new motor i would spend the extra little bit of money for a new set of lifters even if they are stock replacements.
Old 07-01-2008, 04:35 PM
Thanks guys
Old 07-01-2008, 04:44 PM
02b4ccamaro's Avatar
i dont see way you would use solid lifters unless it is a race motor or you plan on spining over 7500rpms
Old 07-01-2008, 05:13 PM
Up to 7500 but no more.
Old 07-02-2008, 07:18 AM
8 second mod
Noyzee's Avatar
since going solid roller i think any motor i do from here on out will be solid roller if its going to be 50/50 street/race.
you can run bigger cams, make more power rev higher etc etc.
im liking the solid roller alot.
and they are not as much work as most think. i put my rockers on 1st of the year, have a good 50 passes and have not touched them. i pulled the covers off once to check them, but thats it
all ive done to my car this year is change the oil
Old 07-02-2008, 11:31 AM
Well if I sell enough parts ill go solid roller. My machinist is really recommending it.
Old 07-02-2008, 11:49 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
If you need anything, rockers, pushrods, or a custom cam give us a call, we would be more than happy to help you with your build.
Old 07-02-2008, 02:13 PM
StevieZ's Avatar
With a 383 4" stroke, you are better off keeping the revs to a max of 6800ish since the piston speed is higher due to the longer stroke. Better off using a cam that makes its power lower so that you can use the full potential of the extra torque a stroker will give you. Hydraulic lifters would be a better choice for that kind of motor.
Old 07-02-2008, 02:19 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
I dont agree.... 402's/408/418/427 motors are all revving past 6800 without a problem.
The stock short rod ls7 spins 7k from the factory with a heavy *** pin.
Old 07-02-2008, 04:27 PM
I bought callies crank and rods if it makes a difference. We are planning on reving to at least 7200, maybe 7500. Depends on how cam works out.
Old 07-02-2008, 05:02 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
My solid Roller 410 is limited to around 8000rpm by the wetsump oiling system but can be revved to 9k without a problem if choose to go drysump.
Old 07-03-2008, 09:58 AM
8 second mod
Noyzee's Avatar
i do as well
Old 07-03-2008, 11:14 AM
Wish I could go solid roller but I don't have money to buys adjustable rockers and all needed for it.
Old 07-03-2008, 11:32 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
with the right components a hydraulic will go 7500 no problem
