best cam for 243 heads non ported yellow springs
Like The Title Says What Is The Best Cam For The Head, With An Ok Not Crazy Idle? I WILL BE REUSING THE YELLOW SPRINGS AND ROCKERS
Oh And That Makes Great #s
Am I reading this right? You want to reuse the stock yellow springs? You're not going to be able to do anything larger than a LS6 cam on those springs safely...
The 243 castings are great though.
ok ill do springs, but i need to use the stock rockers, any suggestions on a cam that will get be 400+ and thats streetable, supporting mods in sig
I use 918 springs, but change them out each winter.
my cam is 224/224 581/581 112+0 XeR
polished 243 heads, TPIS 84 TB,on LS6 intake TPIS Lts, high flow cats, x-pipe and straight pipes MN6
Just over 400 rwhp and rwtq
To the OP just giving you a little info on what my TR224 112lsa did with my portted 243 heads, and trying to get a little info for me at the same time .
My car only sees 3000 to 6750 red line. 4-6 times every 2 min for 20 to 45 min at a time, 3-4 times a day x 2 or 3 days in a row, 2 x a month.
24,000 hard road track miles.
I pull my heads each winter to check the valves, seats and springs. Once in a while I will find one spring that is just slightly off from the others. ( spring compression test ) .
I find it just easer to get new springs each winter and test the whole set. Which are almost Identical in compression. as I dont want to pull heads duing the summer or have a blown engine.
Yes I know there are better springs then 918s but I have had nothing but good luck with them, so I will keep using the 918s
