LS1 Valve Springs
LS1 Valve Springs
I took off the valve cover today to check my valve springs and rods... my engine has been sounding like a sewing machine lately... well i grabbed the springs with my 2 fingers and my thumb and i would move the spring side to side like wiggle it... was is wrong and is that normal?
At the pivit point on the rocker arm you should be able to see if the needle bearing is still togethor. I would think if the needle bearing was bad then the rocker may be setting kinda lop sided. You would also find little needles on your oil drain plug.
The only way to check the pushrods to see if they are bent is to remove all the rockers and pull the pushrods out and roll them on a flat glass.
