anyone knows why this noise happens?
it sounds like if its by the flywheel or behind the stall, i checked all the bolts on the flywheel and they where good and it was not bent either, canit be that the stall went out? cuz it sounds like the noise comes from behind the stall
http://www.youtube.com/watch?v=Aj6zBhz1KuY
What flywheel and what bolts? we had a bad knock noise on 1 where the guy used a stock flywheel and arp bolts and the bolts bottomed out on the crank before tightening the flywheel all the way. it held it snug but not tight enough. we put some hardened washers on it and bam no problem.
just an idea... i can't hit youtube at work its blocked
i flywheels seems fine when it was spinning, did not look bent at all...well the tow truck is about to pick it up and take it to thhe transmission shop and ill just wait it out till i find out whats wrong...hope its just the flywheel or the converter
so you saying you thing the noise is in the transmission but it makes the car not run after just a few seconds?
i believe your either going to have multiple issues like a tranny noise and a drivetrain/ running issue, or its a noise coming from your motor/ problem running in your motor
edit:
actually in the 2nd video the noise gets alot louder when your up near the tire, closer to the engine.
sorry bro
hate to be the bearier of possibly bad news
oh and on a side note unless youve swapped trannies befor which u didnt mention, no 4th gens came with a 700r4
they came with 4l60 or 4l60e's
edit:
sorry bro
yeah its a peice of **** lt1, never liked those engines...i bought the car from my brother just cuz i needed a shell for my ls1 motor...couldnt go wrong for $800..ill just dispose of the engine whne i get to tx
I guess I'm kind of an old school motorhead, I think the LT is a hell of a tough engine. I like the performance of the LS but I just don't know what to think on how strong they are. I have two LS cars and now engine failures as of yet but DAMN! I hear and read alot of **** on here about people blowing up the LS1.
And The Problem For That Noise In My Car Was, My Flywheel Being Cracked.....so It Was Hitting The Block,,,,,,,,it Will Be Out This Sat...thanks Guys For All The Info U Guys Gave Me On Trying To Figure Out My Problem...
