Comp 918's and TSP Torquer V.2
Old 08-21-2008, 06:34 PM
b0pric01's Avatar
Default Comp 918's and TSP Torquer V.2
I have been thinking of getting a cam package for a while now and I believe I am going to get the torquer v.2. The comp 918's are rated at .625 lift and the specs on the v.2 are 232/234 .595/.598 112 LSA. Some people have said I should get the patriot dual springs but I don't understand why if the 918's are rated for .625". I am on a pretty tight budget and my build was just going to be the cam, springs, tsp pushrods, ls2 chain, and arp rod bolts just for extra safety. Does anyone have any suggestions for me? BTW I am here to learn so speak up if you can give me some insight please.
Old 08-21-2008, 07:17 PM
b0pric01's Avatar
Can somebody help me out here?
7845's Avatar
i ran that setup in a LQ9 for 8500 miles. no issues ran fine no valve float
Old 08-21-2008, 07:23 PM
LS1HIGHLIFE's Avatar
I ran my TQv2 with 918s for about 4 months with a lot of valve train noise. I later switched to a set of PRC heads with dual springs. I recommend just saving the extra few bucks and getting the duals.... added security.
Old 08-21-2008, 07:29 PM
sidewayz28's Avatar
my 918s broke less then 10k when running the torquer 2.. cough up the extra cash and get dual springs...or youllllll be sorrrryyyyy
Old 08-21-2008, 07:30 PM
b0pric01's Avatar
this is how I thought the turnout would be. I guess I will just drop a bit more money and sleep better at night. Thanks for the replies.
Old 08-21-2008, 07:34 PM
sidewayz28's Avatar
your quite welcome
Old 08-21-2008, 07:35 PM
b0pric01's Avatar
where do you guys suggest buying the springs from?
Old 08-21-2008, 08:10 PM
ozzyls12001's Avatar
well i will also suguest PAC ,i think new Design Comp's918 are better can handle .625 lift
Old 08-21-2008, 09:16 PM
Blownz28man's Avatar
I bought the V2 and titanium retainders a dbl valve springs from TSP(texas speed) Good choice. Good customer service.
Old 08-21-2008, 09:18 PM
Silver-Dollar's Avatar
TSP should have a cam package with the springs and choice of cam.
Old 08-21-2008, 09:49 PM
b0pric01's Avatar
I am getting the cam from someone I know for $225 which is a pretty damned good deal.
Old 08-21-2008, 11:02 PM
blown03mustang's Avatar
i run the 918s on my torquer 2 and have no issues whatsoever.....i was told when i bought my springs that the duals are just more of a safety net than anything but arent necessary! either way u go ur gonna be fine
Old 08-22-2008, 12:06 AM
7845's Avatar
i wouldnt trust any single spring over .600 lift. the old 918s said 625 so do the new ones. the 918s are fine now for piece of mind and future cam swap i would go duals. personally i wish i would of went with the MS3 at the time instead of the Tv2.
Old 08-22-2008, 12:15 AM
Mong00z's Avatar
Why would you want the MS3 over the Tv2? I'm also trying to decide on a cam and was considering the Tv2.
Old 08-22-2008, 01:21 AM
sidewayz28's Avatar
im running a torquer 2 right now and might step it up to a ms3 or something a tad larger.... the torquer 2 is a SOLID daily driver cam.. time fr something nastier!
Old 08-22-2008, 01:22 AM
sidewayz28's Avatar
patriot golds....
Old 08-22-2008, 05:58 AM
Must be in your tune!!! Mine sucks for daily driveability...lol BTW are your numbers with the juice?
Old 08-22-2008, 06:44 AM
AU N EGL's Avatar
I have had great luck with 918s. This past winter I went to 921s.
I wonder if ppl install springs that are too strong and would that effect the valve seal?
Old 08-22-2008, 07:15 AM
zakk101WS6's Avatar
Why not the torquer V3??? 111LSA??? Little more lift, little less duration on the intake I believe. If you're going to get the springs now anyway, put em to good use ;-)
