low psi...
low psi...
my car runs at around 20-25 pounds of oil pressure no matter how fast or how high the rpms. shouldn't that be a little higher? and if so what could be the problem? thanks
T-Pat
T-Pat
11Second Club
If you're using 10W40 and getting pressures that low, then something is wrong. It's probably the oil pump needing replacement. You don't have any odd sounds like a knock or something in the motor, do you? If so, that might explain it.
I hope, for your sake, that it's just the oil pump. That's probably the cause.
You could hook up an oil pressure gauge directly to the motor, but that's kind of a pain in the ***. The oil pump is a relatively easy swap, should take about 3-4 hours.
When you change the oil pump, there will be 2 different size O-rings for the pickup tube. Always use the thicker of the two. I used the thinner one at first and had crappy oil pressure, so I had to tear the whole thing back apart and stick the thicker one in. I have 150K on my engine and it pulls 35PSI at 900 RPM idle and up to 65-75PSI at higher RPMs. Your engine should be fine once you replace the pump. If not, you have bearing issues.
theres a good chance that the oil pump could increase the pressure, but with 125k, possibly a hard 125k miles, theres probably some wear resulting in increased bearing clearances and causing low pressure, hopefully for you its just the pump, good luck!
More than likely your Oil Pump is having few issues, but also bearing clearances over time, pick up, etc. could be problems.
Hook up a mechanical gauge first to see if it is not the faulty GM gauges.
If still low, pick up an LS6 pump or high volume unit, and replace. Should be 3 hours or so. (While you are at it, you should add in a cam and what not too. )
ok, now sometimes my car shows between 35-40psi but it will eventually drop down to 20-ish. is that moreso the gauge acting up or can that still be the oil pump...
