wanting 380-400rwhp in my ls1 help?
peice me together guys a simple cheap kit parts id want to buy to get me at 400whp rougly while keeping gas mileage over 20mpg, and no nitrous or boost please.. im lookin at mild cams, headers, intakes roller rockers.. basic bolt ons besides the cam.
i so far am tossing the idea of ls6 cam and springs.
1.8 roller rocker
fast x intake and tb 92mm
headers and full exhaust
tune!
not sure if ill be at 400whp or not tho. i just dont wanna tear apart the engine or mess with the heads. cam is bout all ill do in opening the motor up. help??!
1.8 roller rocker
tune!
you may want to look at something like a 224 or 228 range cam and 1.7 rockers look at the sponsors or check out the dyno section to get some ideas. i dont think youll see 400 rwhp with a Z06 cam
Like said ubove get something bigger than the ls6 cam. I would stay away from the 1.8 rockers just get a cam with alittle more lift. What year is your car? If pre 01 get a ls6 intake maifold or a fast, headers y pipe and cat back or true duals. I had a thunder racing cam 224/224 563/563 112lsa, with full bolt ons and made 396rwhp/383rwtq. Check some of the sponsors they sell complete cam kits... cam, springs, push rods and gaskets.
va speeds 228 made 400 id lokk into a cam in that range i dont see 380 with an ls6 but who knows anything is possible...if you had the ls6 heads along withg it yeah it could happen
running 1.8 rockers virtually eliminates most of the popular cams on the market. they are not compatible with most lobe designs.
i'm running the Torquer V1 with stock gears and i still get 25-26mpg highway, and 16-19mpg around town. and that's with a crappy part throttle tune.
LS1Tech Premium Sponsor
Definately look to something a little bit larger in the camshaft area. We dyno tested the 228R TSP camshaft to just under 500 flyweel horsepower on a stock head engine! The 228R TSP camshaft made 490hp & 432 lb ft of torque while the basline before the camshaft made 416hp & 420 torque! How about a 74hp gain from a camshaft swap that drives really unbelieveable!! Give us a call tomorrow & we can provide you with our dyno testing of these camshafts your looking at.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
