WoW > Look at this Dyno Sheet ! (567 torque)
Old 09-04-2003, 07:56 PM
Tin Indian's Avatar
Default WoW > Look at this Dyno Sheet ! (567 torque)
No, this is not my car. This is Dug's "ChevyNo1" dyno sheet.
This dyno pull was is the Phoenix, Arizona heat using [91 octane] pump gas. That's the gas avail there.
Anyway .. 533 rwhp and a massive 567 torque! And all done with a stock block, bone stock headed, and stock cammed 98 Z-28 SS.
This is what about 9 psi of Incon twin turbo boost will do with no engine mods other than good programming and a very good water/alcohol injection system that stops detonation in it's tracks.
I have known Dug since his car was brand new. And, I always thought my head / cam/ headers car could somewhat keep up with Dug's Incon turbocharged ... otherwise stocker Z-28. Well, thats wishfull thinking on my part!
Jeeeze, was I wrong!
Just thought I would show you the dyno chart.
Folks, this car has the stock heads and cam in it! In fact, I don't think the valve covers have ever been off this 98 Z-28.
I believe his HP drops off early in the revs because Dug's MAF becomes maxed out.
Old 09-04-2003, 08:11 PM
Turo's Avatar
Default Re: WoW > Look at this Dyno Sheet !
Old 09-04-2003, 09:39 PM
LS1TECH Sponsor
foff667's Avatar
and look at how rich it was running lol unless the alc. injection somehow messes with that thats a badass graph for an otherwise stock car whats that an 80% gain? Wow
lata
Bill
Old 09-04-2003, 09:48 PM
Tin Indian's Avatar
Bill...
The Alc/H2O injection must have a lot to do with that. Jeeze, if my car ran that pig rich, I would loose maybe 30 rwhp on the rollers. Christ, his fuel/air ratio is off the chart!
And I don't think Dug's 98 made more than about 295 to 300 rwhp (max) before these turbo's were put on it. Simply amazing.
Now the real question raises it's ugly head .. Even though that Alc/Water injection is probably saving his ***, How long will his stock cast Mahle pistons last? Not to mention those stock "cracked powdered" rods seeing that his CR is 10.1:1
It's a "Dicey" game Dug is playing....
Old 09-04-2003, 10:49 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
500 rwhp @ ~3600rpm
What type of exhaust set up does the car have?
Old 09-04-2003, 11:42 PM
LS1Tech Co-Founder
Nine Ball's Avatar
How is Dug doing? He sure doesn't post as much as he used to. Almost forgot about him
Turbos are sweet.
Tony
Old 09-05-2003, 01:29 AM
1BadAzzWS6's Avatar
wow...what kind of times is he seeing with that beast?
Old 09-05-2003, 02:15 AM
mhoward's Avatar
I can't even imagine.........
Old 09-05-2003, 09:35 AM
7 Second Club
NicD's Avatar
He has true dual exhaust on it. It has a very safe tune on it without the alky kit and it puts down 480 rwhp on 91 octane alone around a mid-high 11 A/F. We didn't want to pull fuel out just for the alky kit since it probably won't always be on so that is why it is so pig rich on that graph. His MAF hits right up around 11.0-11.2 khz and that is as far as the 98 computer goes so it is at its limits. I think we have managed to finally exorcize the demons.
Old 09-05-2003, 10:14 AM
ChevyNo1's Avatar
Thanks for the nice words Ron!! My car actually made 334rwhp before the turbos, but that was with gears, pullies, ported MAF, and stock 10 bolt. Pullies are gone, stock MAF is back on, and I'm now pushing this through a locker 9", with pretty well stock ratio 3.50's.
No track times yet, but I hope to be going tonite. I'll be running DR's, so I don't expect a great ET, but am really interested to see what it will trap. Gotta get it weighed too. Ron mentioned good programming. I can thank NIC for that!!
Hey Tony!! How's Houston? I mostly hang out in the FI section, I gotta visit around a bit more I guess! It's been a long arduous journey with my car, but it's finally starting to pay off.
Now the real question is, how long will it last?
- Dug
Old 09-05-2003, 10:29 AM
MEAN LT1's Avatar
- Dug
Hows that smc kit workign for you. Do you have the dual nozzle trunk mount kit on your car?. Also whats so your spray on point and pump speed?.
Old 09-05-2003, 10:31 AM
XFACTOR's Avatar
Sweet-Turbos rock!!
Old 09-05-2003, 10:43 AM
ChevyNo1's Avatar
The alky kit seems to be working well! I have trunk mount, but onl single nozzle. Spray on point is about as low as it will go ( prolly 3psi ) and pump speed is also minimum ( 4.5 on dial ). I was running an 80/20 alky/water mix with this dyno, I'm thinking of dropping to 50/50 so it's not so rich . . . next dyno session!
- Dug
Old 09-05-2003, 12:31 PM
LS1Tech Sponsor
Slowhawk's Avatar
Thats the wonderfull work of turbo's Now if they can only come out with Headers that don't crack we'll be all set.
Old 09-05-2003, 01:30 PM
MEAN LT1's Avatar
Glad everything is going good with the kit. I as far as going to a 50/50 mix I alwasy heard and was told that str8 denatured alky gave the best results but I also everybodys car isnt the same. Im going to try out just alky at firsy with some marvel mystery oil and see how that works out.
Old 09-05-2003, 02:36 PM
LS1Tech Sponsor
Slowhawk's Avatar
50/50 Alky/water works good for us GN guy's that run over 18lbs on the street.
