How much is "too little" PTVC?
I just want to hear some ppl on here admit that they are running smaller than recommended PTVC (.080I, .100E)? I am at .080 on the intake after flycutting the I side but am at .080 also on the exhaust (no flycut), I would cut it a bit but do not have the correct size cutting tool, would/do you guys think .080 on the exhaust is ok? Heads are TEA stg 2 LS6 milled .020 2.04I and 1.57E valves, stock MLS gasket.
What is your Int. clearance? Exhaust is a little on the tight side, and about sure te intake is even worse.
.070+ min. int and .090+ min. exh. is what I shoot for, otherwise you go at your "own risk" and hope you stay off the rev limiter?
Intaake is right where it should be at .080. If I could find the Isky flycutting tool asap for the exhaust I would cut it .030 deep but I have no clue where to get one
Yea I see what you are saying, I clayed it again and its a very small amount over .080, I would say .082 but I went ahead and put the heads on as I do not have a cutter to flycut the exhaust side. I measured my pushrod lenght and got 7.300 with no preload so I think I am going to order the 7.350's...
LS1Tech Premium Sponsor
I've run .040" / .055" one time on my own car. While I don't at all think it's a good idea, I never had any issues with it. Your on the tight side of what guys like to see, but I doubt you have any problems.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
i have never personally trusted the clay method.Instead i use the feeler gauges between the rocker and valve method.Much more accurate,if done properly.I would say you dont want your exhaust that tight is its an m6,if you miss a shift,and have a mechanical overrev,you may have a problem.The intake valve on the other hand is fine.I would just locate an isky tool and sleep better not worrying about the engine staying together,but thats just me.
UNDER PRESSURE MOD
I would run .040 on a auto car.
Not on my m6 car. The syock cam/valvetrain had contact on a 2-3-2 so problems form it I even fly cut later). Also run a good valvespring, even more then needed, if your under good amount of room =.100
And watch the valvetrain weights (aftermarker "better" parts that weight a lot more then stock)
Just bumping this thread to let everyone know how its been at those PTVC numbers. I have ran the car a couple times at the track with the rev limiter set to 7300, (I was trying to make 2 passes without having to shift into 4th gear, it did not help my time so I set it back down to 6700). Also I did the "3rd gear into 2nd gear" shift and saw my rpm gauge fly into the black zone on the gauge, I babied it home and thought the worst, I did a cyl leakdown test @ 90 psi on all cyl's amd had NO leakage other than the small normal air slipping past the rings into the crankcase. Also I have smacked the rev limiter a lot since then and its been great, I will however be changing the valve springs out after 15 or 20k miles. Also my numbers and 1/4 mile time on the set-up are below.
