PRC stg 2.5 heads VS. P&P 241
Old 09-09-2008, 01:15 PM
ZMONSTER!'s Avatar
Default PRC stg 2.5 heads VS. P&P 241
Hey all anyone have any numbers or ideas about the power and flow differences between the 5.3's in my sig vs. a fully ported/polished set of 241 heads? Im curious about this as they are both stock castings. Thanks all
Old 09-09-2008, 10:02 PM
ZMONSTER!'s Avatar
ttt...
Old 09-09-2008, 10:42 PM
SOMbitch's Avatar
Most generally aknowledge a little better torque down low with the 5.3's and a little more up top with the 241's. IMHO it comes down to the port/valve job.
EDIT: Oops. I read it quickly and thought he said 243's. I dunno then....
Old 09-09-2008, 10:55 PM
ZMONSTER!'s Avatar
thanks man, kinda what I thought just wanted to see if anyone had any numbers.
Old 09-10-2008, 11:58 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We've dyno tested the PRC 5.3l head against several difference good quality cylinder heads. That being said I haven't tested any 241 ported heads, most people ebay the 241 castings.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 09-10-2008, 01:03 PM
ZMONSTER!'s Avatar
/\ya I know, but Im interested in this. Thats not to say Im going to give up my 5.3's anytime soon!
Old 09-10-2008, 01:10 PM
strokerblackhawk's Avatar
what do the PRC 2.5 heads flow?
Old 09-10-2008, 01:12 PM
ZMONSTER!'s Avatar
Here is right off of texas speeds site
Intake Flow Information:
.300 208
.400 257
.500 290
.600 312
Old 09-10-2008, 01:26 PM
fauslpss's Avatar
As soon as I get my flow # on my 241 I'll let ya know there not really hogged out. And then I'll get it dyno'd to see the results.
Eric
Old 09-10-2008, 01:30 PM
ZMONSTER!'s Avatar
/\ hell ya man! What all are you having done to them? Whos doing your work?
Old 09-10-2008, 02:19 PM
fauslpss's Avatar
A guy on here did them stock size valves and 215cc intake runners. And I have a shop in NY looking at them and spec'n a cam for me. He should have the heads tomorrow so I'll know the Flow #'s soon.
Eric
Old 09-10-2008, 09:56 PM
MJD
MJD's Avatar
Heads done by Creative Flow Management. 241 cast with stock valves:
lift in ex
.100 77 65
.200 145 116
.300 199 159
.400 243 190
.500 275 210
.600 285 216
This also included a valve job. The intake had only the bowl and opening worked, the runner was left alone to help velocity. I run a cam close to yours (Vinci XXX 222/228) as well. Numbers in sig.
Old 09-10-2008, 10:11 PM
z28poweredlt1's Avatar
lift in ex
.100 77 65
.200 145 116
.300 199 159
.400 243 190
.500 275 210
.600 285 216
Nice numbers for the mods! I like that torque.
Old 09-11-2008, 07:21 AM
fauslpss's Avatar
I like those #'s For the little amount of work and size cam. Torque is up there.
Eric
Old 09-11-2008, 08:05 AM
MJD
MJD's Avatar
Eric
I would say it was more than just a little work done. The exhaust was fully ported, combustion chamber done, valves unshrouded and a valve job. These were hand ported. For comparison the same dyno had a stock C6 Z06 on it. I edged it out by roughly 5-10 rwhp/tq. Who does the port work and tuning plays as big a role as how well a set is suppose to flow IMO. I say suppose to flow because advertised numbers are just that in some cases, advertising.
Old 09-11-2008, 11:47 AM
fauslpss's Avatar
MJD, you said that the intake runner was left alone right? When you got the heads done did you get them flowed with a aftermarket valve?
Old 09-11-2008, 12:58 PM
MJD
MJD's Avatar
No, stock valves only. It would be interesting to see what they would do with aftermarket.
Old 09-11-2008, 03:52 PM
fauslpss's Avatar
The guy in NY was going to flow it with a Ferrea valve, I'll see if hes still going to do that.
Eric
Old 09-15-2008, 04:13 PM
ZMONSTER!'s Avatar
/\ any new news guys?
Im considering getting my 241's p&p and milled then a 230+ duration cam.
my combo works pretty well, ill probably have ptv clearance issues if i go with a larger cam.
Old 09-15-2008, 04:32 PM
In all honesty, I'd probably keep the 5.3 heads lol
Quick Reply: PRC stg 2.5 heads VS. P&P 241
