MS3 Specs????
MS3 Specs????
Ok i called TSP and they couldnt give me the specs of this cam that i want. I know the specs at .600 lift but i want the SAE .006 lifter rise. I am in a high performance engine building class and i would like to see if the cam is optimal for my set up. So if anyone knows these specs please let me know. BTW i tried search.
Hmm I found the MS3 on their website...not sure what the problem could be...
http://www.texas-speed.com/shop/item...d=170&catid=44
Hope that helps.
Hope that helps.
LS1Tech Premium Sponsor
Advertised duration is 286º/291º.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
