will these pistons work in 347?
http://www.texas-speed.com/shop/item...d=791&catid=38
im forged my motor for my f1-a procharger setup, also is 6.125" the standard length on a connecting rod? im looking to get some eagle h-beams! cause it said tsp uses them for the stroker motor setups i was wondering if they would work in a 347ci! Thanks!
Yes that is the size you need. 3.905 is just a .005" hone on a stock ls1. But you also need to make sure it is for the correct stroke. which it is for a stock crack. It has something to do with the location of the wrist pin.
im gonna be using the stock crank, ive heard of them being good to 1000hp, but these pistons and 6.125 eagle h-beam connecting rods! 1200 bucks isnt bad at all for that!
