What cam for 3500 stall and 150 shot
Old 09-14-2008, 07:23 PM
whywhine's Avatar
Default What cam for 3500 stall and 150 shot
Hey I am in the market for a cam, and would like to get some opions. I have a 4l60e with a 3500 stall, ls6 intake, and headers, and a 150 shot of nitrous. I would like to pick up a few tenths at the track. I am currently running 7.1x' on the jug, and 7.8x's on motor(1/8th mile times). This is a street car and I dont want anything to big, I have looked but not seen anything specific to my set-up. Thanks guys!
Old 09-14-2008, 08:05 PM
SOMbitch's Avatar
Nitrous likes exhaust bias so whatever you do make sure it's a traditional split.
Old 09-14-2008, 08:10 PM
pasbonsimon's Avatar
F13
http://www.futralmotorsports.com/fms....asp?pf=1&pg=5
Old 09-14-2008, 09:06 PM
JPH
JPH's Avatar
228/232 .590/.600 111+4 is the biggest I woul put in it.
Old 09-14-2008, 09:11 PM
04gtoBMXracer's Avatar
cam from thunder racing 231/234 .640/.590 112 LSA 2400-6800 RPM Power Band. Excellent mid-range & high RPM power. 3200+ stall, 3.42+ gear, computer tuning required. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Comp 921 Valve Springs are highly recommended.
Old 09-14-2008, 09:24 PM
whywhine's Avatar
I beleive the f-13 is bigger than I am wanting, the cam that JPH recoomend sounds more like what Im looking for. JPH, would that have to be a custom ground cam or is there someone that makes it? Thanks for the input guys.
Old 09-14-2008, 09:52 PM
JPH
JPH's Avatar
Thats a Custom Crane.
Old 09-14-2008, 10:05 PM
TXZ28LS1's Avatar
MTI X1 or TR 230!! tried and true proven cams. im running a vig 3200 and make 395rwhp on stock heads without a pulley.
Old 09-14-2008, 10:16 PM
beedo's Avatar
Wow them some big ole' *******.
Old 09-14-2008, 11:28 PM
Tri5Nerd's Avatar
Really?
BTW: I would go with JPH recommendation.
Old 09-15-2008, 06:53 AM
darrensls1's Avatar
New Era Performance sells the streetsweeper cam in two versions. The smaller is a 228/232 111 lsa which sounds perfect for you. My buddy has that cam with a BBK intake and he ran 11.95 @ 113.80 last week with it. 150 shot on top of that is easily high 10's. Driveability is excellent as well. No bucking or surging at all. Just give it a minute to warm up and you're GTG.
I know they had a few in stock late last week. Give Mike a call at 585-865-1832.
Old 09-15-2008, 08:01 AM
s346k's Avatar
i'd opt for something like a 224/228 on a 110, just because you want it to be very docile on the street. only running a 150 shot - you can run whatever cam you want, the gains will be the same across the board.
