Bad Pulley or Belt
Bad Pulley or Belt
I have been having problems trying to find a loud sqeeking noise coming from the engine. I thought it was my tensioner pulley so i replaced it with a katech tensioner. But the noise still is there and has gotten louder, especially on cold starts. Does anyone have any ideals on what it could be?
Do you have an oil cap breather? Put a rag around it to keep the oil from puking out on the belts. And spray wd40 as a last resort bc once you do, it will make the pulley squeak untill it refinishes its surface back to what it was before you sprayed it. Engine cleaner/degreaser, all that stuff makes your belts squeak bad for 2 weeks, then the belts squeak when there cold.
I'd change the belts, and make sure no fluid is getting on the belts or pullies. Then let the pulleys work themselves quiet over a period of two weeks. And try to diagnose the noise again from a 100% clean slate. Spraying fluids on your pulleys and belts is not good if you want them to be quiet.
I HAVE THE EXACT SAME PROBLEM!!! It's driving me insane! ive used belt conditioner, tried identifying the specific pulley with spraying wd40 and silicone lubricant, and nothing works. when spraying some silicon lubricant it sometimes quiet things down but not for long.
please keep me updated if you find what exactly is making the noise. i am thinking its my water pump...
I have tried the wd-40 route but it seems to get worse. Also I noiced when the car is cold if a turn my front really hard to one side it gets really really loud, only when engine is cold then after the engines warms up it won't make the loud noise.
Exactly.
This is not that bad of a job for most people. The bearings are greased from the factory and that grease dries up. Sometimes it can be the belt, but its cheaper to grease your bearings first, then to replace belts first and find out its still there.
Chances are its the A/C idler pulley or even the tensioner pulley down there (they are the most common to make noise).
It's most likely the water pump. I've done several of these and they always seem to turn out to be the water pump. It's hard to spray lube when using a belt driven fan. The lube seems to quiet the noise for a few seconds no matter where you spray it because of the fan. It turns out to be the water pump in the end anyway. Change the water pump.
Your right. IF the bearing is bad. Most of the time its simply a dry bearing though...not a bad bearing. If the ball bearing ***** do have flat spots, due to neglect of lubrication, they will soon again make noise. Depends on how long this noisy bearing was ignored, thats all. Its a quick & easy & inexpensive test, don't you think?
