GM Hot Cam vs. MTI C1 Cam
Hey guys lookig for some help im about to get a cam for my SS Camaro looking for a cam for my stock heads question is should i go with the GM Hot Cam or MTIs C1 or the other 2 that can work with stock heads im not in the budget to go all out with a head cam package yet i heard this guys SS this weekend asked him bout his internals and said he had a GM Hot Cam sounded nice with the cutout and said its been working for him very well what do you guys think i do have bolt ons Exhaust, Air Lid, MAF, Asp Pulley
i think u can find either one for 400 bucks so any info will help guys appreciate it
Re: GM Hot Cam vs. MTI C1 Cam
I have the GM Hotcam. I have been pleased with it. I was not interested in all out track times, but with a decent running street/ occassional strip car that would be reliable (no spring changes, etc). I think I got what I was looking for. Sounds mean too.
Get the Hot Cam if you want to save money, want a nice sounding lope, and don't want to periodicaly change springs.
Get the C1 if you want a smoother idle and more power, and are willing to pay more money for the upgrade and change springs every two years or so.
The C1 is a more technically advanced cam that will perform better and idle better, but at a price. It will also pass emissions better, though in Texas you probably don't care about that.
appreciate it guys ill look into that GM Hot Cam but how much am i gonna run into as far as getting it installed (labor) im no mechanic so i need a shop to do the trick and what other mods will i need i mean does the Hot Cam come complete or will i need other mods to work with my A4
!LS1 11 Second Club
Wait, you have an A4?! Go with a 114 lsa cam. TR220 for you, or as mentioned the MTI Stealth (115).
You can run a 112 on an A4, but will encounter some idle issues. TB hole/ bump and or tuning will be necessary.
Hotcam not the best choice for an A4.
I had 65,000 miles when I did the swap. I changed
some parts-
Katech Oil Pump
ASP Pulley
Rollermaster Double Row Timing Set
Valve Seals
LS6 Springs (kit)
Retainers (kit)
Thermostat
LS6 Intake
Gaskets
I figured we were in there. Might as well freshen things up a bit. My install cost $400.
some parts-
Katech Oil Pump
ASP Pulley
Valve Seals
LS6 Springs (kit)
Retainers (kit)
Thermostat
LS6 Intake
Gaskets
