Dual Valve Spring recommendations that don't need machining?
Re: Dual Valve Spring recommendations that don't need machining?
I've been using the new Crane dual springs for two weeks now. I believe they are good for 0.650" lift, but don't quote me on that. So far so good!
rev doubles do not require machining ....
i've used them for seveal months with no issues....
see thunder racing ------>
Which is better? Who has the Crane dbls? The only doubles I had heard of were the Revs (that didn't require machining). Thanks
Thunder Racing's website says the Revs can be used with stock spring pocket, it doesn't say anything like that about the Cranes. Does anyone has some documentation that says you don't have to machine anything. I want to ditch my single springs but I don't want to have yank the heads to have them machined. Thanks
The new Crane duals are a direct replacement, no modification to the head is needed. I would use the Crane hardened spring seats though.
Crane duals #144832-16
seat preasure = 112lbs@1.8
open preasure = 352lbs@1.150
The seat preasure is lower than the 918's. Would that cause any problems?
seat preasure = <a href="mailto:112lbs@1.8">112lbs@1.8</a>
open preasure = <a href="mailto:352lbs@1.150">112lbs@1.8">112lbs@1.8</a>
open preasure = <a href="mailto:352lbs@1.150</a>
http://vincihighperformance.com/NEW%...TS%20PAGE.HTML
here's the newest vinci/crane springs
DUAL VALVE SPRING KIT
PERFECT FOR SHAFT MOUNTS OR EXTREME APPLICATIONS
160 lbs @ 1.750
400 lbs @ 1.150
will handle .650 lift with ample coil clearance
NATURAL FREQUENCY MUCH HIGHER THAN OTHER SPRINGS. HARMONICS DON'T EVEN COME INTO PLAY UNTIL AFTER 7200 RPM
EACH SPRING IS MAGNAFLUXED BEFORE PACKAGING
COMPLETE WITH TITANIUM RETAINERS & ID SPRING LOCATORS ( NOT NECESSARY TO MACHINE HEADS)
160 lbs @ 1.750
400 lbs @ 1.150
Geeeeze.. ...This thread is very very old..it came back from the dead .. PRC duals and Patriot gold duals are good and require no machine work..I put 43000 miles on a set of TSP's PRC platinum dual springs with a cam with .595 lift without any problems..
Both PRC and Patriot now have dual springs that will handle .650 lift..
