SPEED INC. FAST LSX-R - NW 102mm TB dyno test
Old 07-09-2009, 08:32 PM
qqwqeqwrqwqtq's Avatar
Default SPEED INC. FAST LSX-R - NW 102mm TB dyno test
I finally had some time today to do some testing with the new Fast LSX-R intake manifold and Nick Williams 102mm throttle body.
Vehicle specifications-
2008 Z06, 5k miles. Speed Inc./Comp 228/242 117 cam, ported LS7 intake manifold, stock throttle body, Vara-ram induction, Kooks headers and X-pipe. No cats. Stock mufflers.
Test specifications-
All dyno runs were made with water temp at 200deg and oil temp between 190-200deg. No cool-down runs were made, I wanted absolute consistency. I made three baseline pulls and three pulls with the FAST intake/NW TB. The car was not shut off between runs but was allowed to idle and cool back down to 200deg temps before the next run was made. Anyone interested is welcome to the HPT logs.
The tune remained the same between both intakes with the exception of some etc scaler and idle airflow adjustments for the 102mm throttle body. Air fuel ratio is 12.85.
Stock LS7 injectors were used for both tests and they were reaching 89% duty cycle.
Conditions remained very consistent throughout the day. Baseline was between 85.13deg to 85.71deg, 26-27% humidity 1.02 correction SAE.
FAST runs were between 82.29 to 82.84deg, 27-28% humidity 1.02 correction SAE.
Test results-
Baseline runs with ported LS7 intake and stock throttle body-
Dynorun 54. 513.85rwhp 458.71rwtq
Dynorun 55. 512.10rwhp 457.69rwtq
Dynorun 56. 512.29rwhp 456.61rwtq
Test runs with out of the box (untouched) LSX-R intake and NW 102tb
Dynorun 57. 526.09rwhp 481.39rwtq
Dynorun 58. 528.84rwhp 479.98rwtq
Dynorun 59. 528.49rwhp 479.35rwtq
I was rather impressed with the results. Comparing the best ported LS7 run to the best FAST LSX-R run, gains were 14.99rwhp and 21.27rwtq at peak.
In other parts of the curve gains were up as much as 23rwhp and 23rwtq.
If interested in this combination please email fraser@speedinc.com
Any questions can be posted here or you can contact me at jim@speedinc.com.
:thumbs:
Old 07-10-2009, 03:53 PM
fastGBcamaro's Avatar
I wonder what some porting could do to the FAST. Really nice gains for staight out of the box though.
Old 07-16-2009, 11:09 PM
'02 WS6's Avatar
very nice.
x2 on the porting.
I'd like to see what it would gain over a factory LS7 intake, or even a ported 102mm over factory/ported LS7 intake!
Old 07-17-2009, 12:04 AM
MASS seller approved
smok'nZ's Avatar
yes we need to see a test of unported vs unported and ported vs ported
Old 07-17-2009, 02:10 PM
DBN
DBN's Avatar
Did you use the 85mm or 100mm MAF?
Old 07-17-2009, 04:42 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
sorry to jump in, but if its an LS7/Z06...there is no MAF housing. its just the sensor that plugs into the side of any intake tubing....some people need to research i think. this has been posted in a few of the LS7 dyno threads...
Old 07-17-2009, 05:30 PM
camaropilot's Avatar
So is the C6 Z06 uses a sensor that plugs into the side of an intake tube can we LS1 guys convert to using that style sensor for less restriction in the intake track?
Old 07-17-2009, 05:39 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
the non LS2 C6 use that sensor both the LS3 and LS7.....im sure something could be arranged....
Old 07-18-2009, 10:51 AM
It would be a good mod and im sure cheeper than aftermarket
Quick Reply: SPEED INC. FAST LSX-R - NW 102mm TB dyno test
