Lq4 cams
Ive got one for sale that I would let go cheap. I can get the #s for you if you're interested, but it's very similar to the GM hot cam. wasn't enough for what I wanted with my lq4 so I went bigger.
astuatjasarjkkl
I was actaully surprised on what it put down. I built the car to drift/road race so its more than enough power. If i were to up the compression/valve job I would like to go bigger.
im going to run stock heads, go with an ls 2 or 3 intake , stock manifold and a built 4ls65e tranny . I may boost its later down the road but not to sure yet . awesome looking car you got there by the way .
Torque converter will play big role to depending what cam you end up going with so make sure they will work togeather, how high stall are you thinking u will want to run?
