FAST LSX-RT intake questions
I have an engine with PRC 237 cylinder heads and a FAST LSX-RT intake. Anyway I need your guys opinion whether this is right or not. When I look down the injector hole in the intake I can see part of the cylinder head. The cylinder head actually is shrouding the hole.
LS1Tech Premium Sponsor
Here is the same picture on a 150K miles stock long-block (Iphone pic). This is very common and not a problem at all.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Nope, our ports are in the same location as stock.
__________________
Just checked it with 2 more brand new intakes to make sure it wasn't a one time problem with the intake, same thing on all. Checked it with a stock LS2 intake, different because of the smaller size of the hole but still there.
__________________
Any of the FAST intakes will be this way. You could go LS6, LS2, BBK, etc but it would cost you significant power.
It's the same exact layout that everyone running this intake has....FAST ASSumed there was a problem without looking into the issue instead of researching it for you. Install and let her eat.
__________________
Larger chambers, yes...larger runners, no. They are virtually identical (very small difference, much less than seen here).
__________________
MASS seller approved
not the only one as i have one too but this is ls1tech so mostly cars and they use the car intake, not the truck intake.
on performancetrucks you would have more folks with trucks and truck intakes.
i didnt check mine but only issue is idlling issue which seems to be common with these fast truck intakes. other than that, power is very good.
Without a problem....Intake can take up to 67psi, so unless you have an LS diesel, your in good shape. Here are some articles both over 20psi, both over 1000hp....
http://www.gmhightechperformance.com...6/viewall.html
http://www.hotrod.com/techarticles/h...g_bang_theory/
