fast fuel rail??
fast fuel rail??
Doesn anyone make a line to connect my fast rails to the stock push clip location on my 2010 camaro ss ??? If so any part numbers would be most.appreciated
http://www.peakspeedshop.com/attachments/Image/FAST_PRODUCTS/Torrent_Fuel_Line_Kit.jpg
These lines are from a vendor here. I used Russell Universal hose # 658500 and fittings #644120 to connect to stock rail. You would only need one fitting for your application if the FAST fuel rail has -6 AN line in.
On my G8 GXP I used a FAST adapter fitting to hook to my stock fuel line and then ran -6an line to the fast fuel rails. Here is the link to the fitting I used. http://www.compperformancegroupstore...=FuelSystemAcc
This hooked directly to my stock fuel line that comes up on the back of the firewall. A lot between the Camaros and G8's is very similar. If there is any doubt I would contact FAST to make sure it would fit your application. Not sure if you are wanting to run -6an line to your fuel rails or not but thought I would let you know what worked for me.
Tony
Tony
