Ported LS7 Intake Manifold Dyno Results
We just received dyno results and this note from Barry at Jerry's Chevrolet Corvette Center in South Dakota. They installed the Radically Ported Intake Manifold and Ported Throttle Body from Peak Speed Shop and are thrilled with the results. We love getting the before/after dyno reports from shops like this because they reflect non-biased results of our work. Take a look.....
Bob - Peak Speed Shop
Bob,
It’s been awhile since we spoke but I wanted to share with you the results of the installation of your radically ported LS7 Intake and Throttle Body. Attached is a dyno sheet showing before and after results of installing your radically ported intake and ported throttle body. I want to tell you that this car is a 2009 Corvette Z06 with long tube headers, a performance air filter, performance camshaft and OEM mufflers – It has been dyno tuned before the installation of your parts. It is running 92 octane pump gasoline. The before and after results show only the addition of your parts – we didn’t do any tuning to influence the results. The gains were very similar to your estimates. Peak power rose 15.74HP and peak torque went up 10.67 ft/ lbs at the rear wheels. What is more impressive than the peak numbers is the fact that the power gains were much larger in the lower RPM range. Take a look at the graph at 3500 RPM – before the ported intake and throttle body the power levels dipped a bit as the cam “started to come into its own”. With the ported intake and throttle body installed the power levels do not dip at all and gain close to 30 ft/ lbs of torque and 20 HP at the rear wheels! To say the least I am very impressed by your products and service.
Thank you.
Barry Konken
Jerry’s Chevrolet
Corvette Center
Beresford, SD
Bob,
Thank you.
Barry Konken
Jerry’s Chevrolet
Corvette Center
Beresford, SD
Last edited by peakspeedshop; 07-05-2012 at 06:12 PM. Reason: changed dyno graph to jpeg
Stock LS7 Intake Manifold Photo:
Check out our new online store!
Go to http://peakspeedshop.com/Zen_Cart/ to check out our new online store.
Order intake manifold porting, throttle body porting, FAST products plus intake parts.
Now, you no longer need to wait while you ship us your parts for porting. Pay a core charge to get the most common LS2, LS3 and LS7 parts from our inventory and be up and running the same day! Core charges are refundable once we receive your cores back. Order online at our new store!
For more information on Peak Speed Shop Services, go to our regular website at http://www.peakspeedshop.com/ . You can access our store from there, too.
