Fuel injected single plane LS7 intake?
Old 02-02-2013, 06:19 PM
Marble_Sharp's Avatar
Originally Posted by Ego Killer
no I bought it.
And it looks MEAN in your car!
Old 02-02-2013, 06:25 PM
Originally Posted by Dazzak75
How did u hook up the dbw to the cable? This is the setup that I was looking for
A local shop, Modern Muscle, customized a set-up for me to run dbw. They used an LS2 throttle body actuator...
Old 02-02-2013, 10:56 PM
Dazzak75's Avatar
Thanks for posting the pics for me mate, I am going to follow the same principals and mod one for my VE, it will look great and different to anything in Australia with DBW.
I have contacted MAST to get their intake, now to find a throttle body, for an LSX 454 what would you guys recommend? and it would be modded to this set up.
Cheers again, appreciate
Old 02-03-2013, 03:40 PM
Dazzak75's Avatar
Luck you, you got in before I did, I would've loved this unit, but it's ok, i'll build another one.
But if you could do me a favour, can you measure from your valley plate to the top of the air filter for me, I would be appreciative, I am just trying to work out whether it is going to stick through the bonnet of my VE and if so by how much so I can get a scoop organised.
Cheers
no I bought it.
Old 02-03-2013, 05:29 PM
Cheers
Make sure you figure in that you will need at least 3"+ clearance all around filter, anything less than that and it will not perform to it's potential. Also, I think it would perform better with about a 2" spacer by the throttle body.
Dazzak - if you contacted modern muscle, they may sell you the dbw set-up. With shipping though, it would probably be more cost effective to just buld your own.
Old 02-03-2013, 09:27 PM
NOS327's Avatar
For you couple guys trying to figure out twin throttle body options, I've got a blank hi ram top plate I'd sell pretty cheap. Was going to do twin 90mm dbw throttle bodies on a holley hi ram, but went another route..
Pm me.
Old 07-17-2013, 11:04 AM
Briou's Avatar
Originally Posted by Marble_Sharp
I have a MAST 4500 LS7 that I am thinking of getting rid of.
It has a FAST 4 barrel 2000 cfm body. Throttle body is cable driven, but has a custom set-up that utilizes drive by wire. Drive by wire is easily removed if you choose.
K and N Filter... have both 2" and 4".
I know this is an old thread but what is the height of the throttle body from the valley cover to the top face of the throttle body? I am trying to figure out the hood clearance for my Chevelle build!
Old 07-17-2013, 07:25 PM
Gray86hatch's Avatar
I don't have a valley cover but you will need about 10" plus height for the filter.
Tim
Old 07-18-2013, 06:34 AM
Ego Killer's Avatar
mine is right at 11" from the valley cover to the top of TB.
Old 07-18-2013, 10:34 AM
Briou's Avatar
Thanks Guys that is exactly what I was looking for...I really appreciate it....
Old 07-18-2013, 02:09 PM
Ego Killer's Avatar
If you need a filter I have the 2 that came with this deal I would sell, I cant use them.
Old 07-18-2013, 02:19 PM
  #32
8ty8 LS1's Avatar
is there a super vic out for the LS7? or are we still looking at the vic jr? (besides the mast, gmpp, and lsx dr of course)
Old 08-12-2013, 03:00 AM
  #33
Dazzak75's Avatar
Hi Guys, I know an old thread, I have built a similar system using the GM LS7 single plane, 2" spacer and edelbrock 1600cfm throttle body, just fitted and starting to tune, when you were running it, what software were you using to tune, HPT or EFILive? I would like a copy of the tune file to see throttle body settings as mine is going onto limp mode on WOT.
Cheers
Here is a pic of mine on my ute, any help would be appreciated,
Old 08-14-2013, 06:07 PM
  #34
lt1773's Avatar
Cheers
Hi
Nice setup man but how did u convert tb from cable drive to DBW ?
Old 08-17-2013, 05:59 PM
  #35
Dazzak75's Avatar
I am still using DBW, I have that mounted at the back in a housing and using a lever and adjustable arm to operate the DBC TB, works quite well, just some manifold pressure issues, I am losing 6kpa around the 3500 mark. Just wondered if the 1600cfm can't keep up and whether a 200cfm or bigger will correct the issues
Old 10-10-2013, 01:05 PM
  #36
8ty8 LS1's Avatar
what are you guys doing for PCV (if converted to wet sump like i will be doing)? is there a port on the 4150 throttle bodies? or are you guys using catch cans for the clean side?
Old 10-23-2013, 01:58 PM
  #37
C5_Pete's Avatar
anyone have an answer for this?
Old 08-13-2014, 02:51 PM
  #38
1_bad94Camaro's Avatar
Originally Posted by Gray86hatch
Bringing this thread back from the dead. What intake setup is this? I'm looking for something just like this For my C5 427 build
Old 08-17-2014, 10:16 AM
  #39
BennyB's Avatar
looks like the MAST 4500 setup to me
Old 08-17-2014, 10:22 AM
  #40
Yes mast 4500. It is tall. Would need a cowl on a C5
Tim
Quick Reply: Fuel injected single plane LS7 intake?
