LS3 480 throttle connector
I have a 480 crate. I want to (try) adapt a different pedal to.
I need the actual pedal connector as a separate connector. Not the harness side. Does anyone have a clue of this info or how to find it?
TIA
Jared
TIA
Jared
These are the different pedal connectors that EFIconnection.com has. Figure out which one from this.
https://www.eficonnection.com/home/c...terForm=Filter
Then go to Mouser or https://theelectricaldepot.com Or Google it & see if there is a mating connector.
For example, I picked this one:
https://www.eficonnection.com/home/p...ctor-pigtail-2
Then Googled: Mouser delphi 6 cavity gt 150
Entered 6 cavity & found:
http://www.mouser.com/Delphi-Connect...z0zlezZ1yvsm2c
This page on theelectricaldepot.com has the terminals, seals, listed also. Looks like the disassembly & crimp tools are there too.
https://theelectricaldepot.com/weath...-series-sealed
Those look like actual GM Part numbers that you can use to find anywhere.
