L76/L92 Guys..
L76/L92 Guys..
If you can, post up what numbers you have gotten out of your setups, and what you have built.
I am Dynoing here soon..I'm wondering what you guys have so I can compare it to mine for a rough idea..
https://ls1tech.com/forums/generation-iv-internal-engine/662314-l92-dynojet-numbers-plus-plan-b-c-d-e-f.html
505/475 at the wheels.
402ci LS2 11:1 compression
STG 3 Livernois L92s
stock L76 intake
240/252 .650/.661 114+3 cam
1 3/4 jet hot headers
stock LS1 MAF
should make more once i go with bigger headers, go speed density, put an underdrive pulley on, and hopefully ill have another option for intake manifold
stock L76 intake
stock LS1 MAF
Originally Posted by 89Formulaws6
i'm new to tuneing but how to just going over to speed density help you pick up more power, cause when i take mine to get tunded, and converting isn't hard i'd prolly do the same
if your maf isnt pluged in or doesnt work, your car goes into speed density mode
Originally Posted by WKMCD
Speed Density won't net you more peak RWHP than a properly tuned closed loop engine. It can improve drivability with larger cams.
thanks for the help
thats like saying a stock throttle body will make just as much power as a 90mm
