LS2, LS3, LS6 valve springs....Same?
Old 05-05-2009, 05:10 PM
old motorhead's Avatar
Default LS2, LS3, LS6 valve springs....Same?
Have a set of each and they're all three yellow. Are they the same? Thanks.
Old 05-06-2009, 06:49 PM
Anyone care to take a shot at this one? They look the same to me.
Old 05-06-2009, 07:39 PM
c6r
c6r's Avatar
The ls6 & ls3 have a higher lift cam ratio than the ls2. 550 lift for the ls3 & ls6. If you are going to go larger don't even think about using them.
Old 05-06-2009, 08:30 PM
SweetS10V8's Avatar
Check them in a spring checker....You tell us
Old 05-07-2009, 06:20 AM
Have no intention of using them. I have Patriot Golds on my vette and truck. Just trying to sell them. Everyone wants the LS6 springs. Not much interest in the LS3 and LS2 springs. Just thought someone might know if there was a difference. Guess I might call my friendly neighborhood parts man and see if the numbers are the same.
Old 05-07-2009, 08:23 AM
jetblast's Avatar
anyone of those set have this p/n 12586484.
Old 05-10-2009, 01:53 AM
Troux's Avatar
LS2 = LS6 from recent checking. I have found sources on this site rating them at .580 lift, but sources from GM rating them at .570. Can't say on LS3 springs.
Old 05-10-2009, 03:21 AM
HSV-GTS-300's Avatar
GMPP Catalog 2009 says LS2/LS3/LS6 springs are the same.
Old 05-13-2009, 05:05 PM
LS1TECH & Trucks Sponsor
bg-sdpc's Avatar
Yes, the LS2, LS3 & LS6 springs are all the same. Even the later model truck engines have the LS2 heads on them with the same spring.
Old 05-19-2012, 08:05 AM
SSthunder49's Avatar
Hey im hoping i can get some good answeres seeing as the mechanic who changed the cam in my mates ls3 is an idiot... when they changed the cam they left pretty much everything else around it stock and he wasnt very specific on what the sizing of the cam was. Its been pushing roughly 480kw at the flywheel but now im pretty sure 1 or more valve springs have broken, just seein if i can get some info on what the best valve springs are to replace these ones with ? thanks
Old 05-19-2012, 09:19 AM
litle88's Avatar
What cam do you have? That idiot probably left the stock pushrods too!
Old 05-19-2012, 01:13 PM
im not sure what cam he used in it unfortunately, im pretty sure for some unknown reason they just changed the cam. so next weekend i shall be pulling it apart to find out whats been or hasnt been done there and fix it myself for my mate...
Quick Reply: LS2, LS3, LS6 valve springs....Same?
