Need sensor help...cam and crank
So heres what i got: LSX block 427 going into a 2003 silverado. I am using the 24x wheel now and an ls2 front cover.
Am i going to run into problems with the different cam sensor? I'm not up to date on all the 1x, 2x, 4x cam sensor stuff.
I want to break the engine in on a stand and check for any problems at my local engine builders shop, so im planning on buying a MSD 6LS controller. Will the 24x MSD 6LS work with the ls2 cam sensor?
Or do i have to install the 58x wheel and buy the 6LS-2 to run the engine...then buy the lingenfelter 58x to 24x converter to run the engine in the truck?
Im really confused on this at the moment.
