Patriot Heads quality?
Old 09-02-2009, 03:01 AM
Ls2 cruiser's Avatar
Default Patriot Heads quality?
Would members have any comments on the Patriot heads in general. Some members may have experiences they could share. I am thinking of purchasing some. Cheers Russ
Old 09-02-2009, 06:55 AM
BigRich954RR's Avatar
There stock heads that have been ported. There good. Im trying to figure out what your asking ? Takes 2 week for them to build a head for you but you can change a few things when you order them if you like. Chamber CC and stuff
Old 09-02-2009, 08:35 AM
Daredevil_TA's Avatar
I have a set of their stage 1 ported Ls6 heads, i like them.
Old 09-02-2009, 08:54 AM
RAACCR's Avatar
I had Patriots on my FRC 'vette. Loved 'em; great product at a great price.
Old 09-02-2009, 09:48 AM
TACE02's Avatar
I have a friend that installed a 408 in his Camaro and put Patriots on, and ever since, he has been wanting Trickflows...
I personally learned from him and others with cheap budget heads and got it right the first time and saved up for a set of Trickflows. I think the AFRs are also very good heads. Did a little research and found that both Trickflow and AFR have very good exhaust CFM compared to ALL other heads, Trickflow has better intake CFM though compared to AFR. But to each his own.
Old 09-02-2009, 04:08 PM
ringram's Avatar
The cnc job is pretty rought and ready. Im sure they do the job, but in comparison to the higher end stuff they are lacking a bit.
Old 09-02-2009, 07:09 PM
I am asking because they are half the price of AFR heads but their flow figures are extremely good. I dont want to import them to AUS and find they are no good. Cheers Russ
Old 09-03-2009, 07:37 PM
bryanracing95's Avatar
patriot heads are junk! I am having ls3 heads and a custom cam done for my trailblazer by advanced induction. They do awesome work and are very well priced. www.advancedinduction.com, customer service is great
Old 09-03-2009, 07:44 PM
ZMONSTER!'s Avatar
Honestly if I had to do it all over again I would either get my stockers ported (just found out there is a pretty good head porter i my area) or get some AFR's. Dont bother with anything else.
Old 09-03-2009, 07:56 PM
If going to be importing them save up and get the Trickflows as cast then much better heads . If you can wait and save up more get the CNC trickflows
Old 09-03-2009, 11:42 PM
RyanSws6's Avatar
They are ok, can't beat the price. BUT don't expect huge #s. They are great for OE replacements but it you want to get to a high level. Then forget them.
I had them on my 408 got 455/455 and peak 5800. I tore it appart 2 days later. I went LS3 top. I did the math. The LS3 top was better $$$. It pulls so much more up top. It should be close to my 500 goal. I left the cam from the old setup for now. I'd like to dyno it then swap the cam. I figure low 500s with the cam and more once the FAST(if ever) comes out. I should've gone this route to begin with!
Old 09-04-2009, 12:13 AM
jegten's Avatar
can they be improved by someone who knows how to port and prep heads?
Old 09-04-2009, 08:34 AM
Thanks for all the input and any info on any of the US heads is appreciated. Trick flow are well thought of and AFR here has a good name. Are there other US brands and comments? Cheers Russ
Old 09-05-2009, 08:25 AM
mike c.'s Avatar
Stock ported heads. I had a set of stock ported on my first set up and was happy. Then I switched to AFR205cc and gained 40 more hp.
Old 09-06-2009, 01:41 AM
MASS seller approved
smok'nZ's Avatar
if you are FI i would buy a set of #317's and send them to brian tooley @ TEA and have them cnc'd he will do a great job they have tfs there as well
Old 09-06-2009, 06:18 AM
What are the 317's? cheers Ruus
Old 09-06-2009, 10:59 PM
NemeSS's Avatar
whats the going rate?
Old 09-06-2009, 11:01 PM
NemeSS's Avatar
found 01-07 6.0 lq4 and lq9
same intake and exhaust ports as ls2 243 and 799.
only difference is larger chamber=71cc
243/799=65cc chamberc
same valves.
Old 09-06-2009, 11:03 PM
NemeSS's Avatar
Gunnar with PATRIOT used to be real active on this site, some time back.
havent seen on here for some time now, perhaps they are no longer sponsor here.
Old 09-06-2009, 11:11 PM
Gregory's Avatar
Good value for the dollar. Fine for a medium build 5.3 -- 6.0 liter. I owned two sets
