MAX c.i.d. with stock ls2 crank
Pretty much everyone has said it already....if you leave stock bore and stock stroke, then cubes stay teh same. If you want more cubes, then you HAVE to change either the bore size, or stroke or both, which means, you are gonna have to change out pistons at the very least (If you bore, you need bigger pistons, if you stroke, need different pistons because of pin location as well as teh crank and rods)
off set grind crank?
http://www.flatlanderracing.com/cran..._services.html
maybe i wasnt clear enough
they say you can go to a 3.8 stroke just wondering if anyone has done it or know what the end result would be
ok wait i found it they did it to a ls1!!!
http://www.chevyhiperformance.com/te...ons/index.html
