Torquer V2 + L92 heads ??
I already have a Torquer V2 Cam 232/234 .595 .598 112LSA and I want to put it in my new 6.0L with L92 heads. I've read that L92 heads sometime don't work well with cathedral ports oriented cam. L92 will be fully ported with ported LS3 with around 10:1 - 10.5:1 of compression.
Do someone had tried this head/cam combo or have a opinion about this setup? Thanks
LS1Tech Premium Sponsor
Are your L92 heads stock or ported? For a stock head, the V2 would work better than the V3 because in stock form the heads don't flow as well up there at .650" lift, so the lower lift is better suited to the heads. Ported heads however (or at least the PRC porting) will flow better at .650", and your cam should be designed with a bit more lift to get the benefit of that extra flow.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
For a stock L92 head, the TorquerV2 is a decent camshaft....that being said, it is not the optimal choice for those heads. So if there is money in the budget for a cam swap, you could sell that cam and be out very little from your pocket, and get a camshaft better suited for those heads.
__________________
best option for your money is to get the heads flow benched, then send the flow card to texas speed, or somewhere like that and get a custom ground cam to match your heads, thats where you will save the most time
It's pretty well known what the stock L92 heads flow, so that's not a major concern or reason for the OP to spend more money for flow testing. That is, of course, as long as they are stock unported heads.
__________________
I have a TV2 because it was in my LS1 with PRC 5.3 stg 2.5 but it blow. So now I have a 6.0L LY6 with L92, but i want to reuse the TV2 temporary because I'll build a 408 with a custom cam in the futur. I wanted to know if the TV2 will perform better with stock or ported heads. Currently they are unported and they flows :
.100 - 75cfm - 56
.200 - 151cfm - 115
.300 - 214cfm - 155
.400 - 268cfm - 182
.500 - 294cfm - 202
.600 - 320cfm - 204
but I can port it by the same guy who test it, he reached 356cfm at .600 on a other set. Hand ported, old fashion guy!
.100 - 75cfm - 56
.200 - 151cfm - 115
.300 - 214cfm - 155
.400 - 268cfm - 182
.500 - 294cfm - 202
.600 - 320cfm - 204
Works nice, very torquey aswell. You can keep comp around 10.5:1 with that cam and run 27 peak timing. Some people run more but you start to get a lot of negative torque before they knock with those heads.
