Why is the 2008 LS3 and 2007 L92 harmonic Balancer's different?.
Hi everyone,
I ran into a little problem today with the 2008 LS3 and 2007 L92 Harmonic Balancers.
The 2008 LS3 harmonic balancer has a small notch or grove at the tip that goes in the crank for another seal there and the 2007 Cadilac Escalade L92 harmonic balancer dosen't. WHY?
I know they are offset by 1 1/2 inches. I took some picture for you guys to see and let me know why or what is that seal for on the LS3.
Or does the L92 Balancer come with a seal too that I don't have.
just in case you guys wanted to know I'm installing the L92 Truck accessories and A/C on a LS3 engine using the LS3 waterpump with 1 1/2 inch spacers
I cant use the LS3 Accessories because the A/C Compressor touches the A-arms.
an the truck A/C Compressor does not touch at all.
This is the Seal I'm talking about.
The L92 balancer has no groove or notch for a seal
The LS3 Balancer has a groove where the seal goes
picture of the LS3 Balancer seal
Upside down
the seal on the LS3 Balancer
Upside down
Well, one is a truck and one is a Corvette. Low profile vs higher profile accessory drive/pump/balancer.
The "seal" if I have been informed correctly is a diamond embedded anti rotation washer to stop/help stop the Corvette balancer from moving on the crank. It goes between the balancer and the spocket and bites into each. Seal is simply to keep the oil on the inside. (maybe someone on here knows better than that. certainly an odd explanation, but possibly quite true.)
They are around $20 list last I checked, so there must be diamond in there
I need to use the L92 balancer.
LS1TECH & Trucks Sponsor
It does not.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
it's ok for me to use the L92 truck balancer without a seal on the LS3 engine.
I just wanna make sure its ok, sorry if I'm asking too many questions.
it's just that I want to make sure because the LS3 balancer had a seal and the L92 truck balancer didn't
Now I can order the underdrive truck balancer pulley and the overdrive alternater pulley.
anyone else have more to say before I go order the pulley's.
you shouldn't have any problems
__________________
__________________
If it is then I can use a camaro waterpump that has the low water hose on the driver side. Hmmmm Will be great for v8 swaps on a S10 blazer.
Whileas I have not done it, I don't see any reason as to why that wouldn't work perfectly.
__________________
12620556 - LS Harmonic Balancer, damper with pulley. OE replacement for LS3 engines. 12620556
This balancer must be used when installing a GMPP serpentine drive system.
Replaced by PN# 12635649
Detailed Description
This balancer works with all wet sump LS engines (not for use on LS7 or LS9 dry sump engines).
This is the balancer that GM recommends to use with the GMPP serpentine drive systems.
Balancer Washer MSRP
$ 19.86
Enlarge image [+]
"Part# 12600525
Balancer Washer. Designed for LS3, LS7 and L92 engines."
$ 19.86
Enlarge image [+]
"Part# 12600525
Yeayyy I found my answer with proof
2008 LS3 engine has part 233
I see a harmonic damper seal for the LS3 damper but no seal for the L92 amper
2007 L92 engine doesn't have part 233
