2006 LS2 What reluctor?
Converter box or change out the crank and cam reluctors.
LS1Tech Sponsor
24x vs 58x
GM didn't make a clean change over when the switched from the Gen III to the Gen IV small block engine. They made the ECM and reluctor tooth count change over at different model years within the vehicles (for probably a host of emissions, manufacturing, inventory, model year change out etc. reasons).
A few more LS2's to add to the list:
Page 12 of our 58x to 24x converter box (TRG-002) instructions has a good chart showing what vehicles have what reluctor wheels:
The instructions can be downloaded here.
Page 11 has good pictures of the different wheels/cam gears as well.
The crank sensors are different so that can sometimes help you identify which engine you have (you can also look inside the hole when you remove the crank sensor and you can remove the front timing cover to see the cam gear):
• The 58X CKP sensor (GM part # 12585546) is gray in color and has a different connector key than the 24X CKP sensor.
• The 24X CKP sensor (GM part # 12560228) is black in color and will NOT work with the 58X crankshaft reluctor, so you cannot use the sensor from your existing Gen III V8 engine.
As noted above, the sensors are designed to work with the specific tooth count so if you swap engines and don't change the reluctor you need to keep the correct sensor for that gear (if you change wiring/ECM or you our converter box).
The 24x system works perfectly well so if you have access to a 24x reluctor engine or are taking the engine apart anyway, I would recommend changing to the 24x reluctor wheel. If you aren't planning on taking the engine apart and you already have a 58x reluctor engine, then our converter box is a simpler/lower cost way to make the swap.
Hope this helps.
- 2005 Corvette LS2 has 24x
- 2006 Corvette LS2 has 58x
- 2006 CTSV LS2 has 58x
- 2006 Trailblazer SS LS2 has 24x
- 2007-2009 Trailblazer SS LS2 has 58x
- 2005-2006 SSR has LS2 24x
- 2005-2006 GTO has 24x
Hope this helps.
LS1Tech Premium Sponsor
All the 24x crank reluctors correspond with a 1X cam reluctor!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
LS1Tech Sponsor
E40, E38 and E67
No, none of the 24x engines were controlled by an E38 or an E67.
The E38 and the E67 ECMs are both only used on 58x Gen IV V8 engines (as well as 4 cylinder and 6 cylinder applications).
The 24x Gen IV engines were controlled by the E40. The earlier 24x engines were controlled by the Warren (Delphi) PCM.
Hey guys, I just picked up a LS2 from an '05 'vette. I was expecting to need to replace the crank or replace my PCM. Looking to do a little research and choose a direction I found this thread and see that a 2005 should have a 24 tooth reluctor. So now that issue is behind me, are there any incompatabilities with the PCM in my 2000 Fbody and that engine. I'm assumin my harness will be OK for the swap. I found another thread that was very detailed, meant for LS into non LS cars, but seemed to be good information. Guy said that the 4.8 to 6.0 were common platform. Do any of you guys know any issues I need to plan for going ino this swap concerning the harness/electrical/PCM?
Hope you guys don't mind the hijack, let me know if I need to take the ? to a new thread.
Thanks,
Tim
Thanks,
Tim
LS1TECH & Trucks Sponsor
Thanks,
Tim
Thanks,
Tim
You'll also need a cam/knock sensor harness.
If you use the LS2 intake you'll need a map sensor extension harness.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
LS1Tech Sponsor
2005 to 2007 LS2
Don,
All 2005 model year LS2 engines (GTO, Corvette, SSR) were 24x reluctor wheel engines and use the E40 ECM.
All 2007 model year LS2 engines (Corvette, CTSV, Trailblazer SS) are 58x reluctor wheel engines and use the E38 (Corvette) or E67 ECM (CTSV and Traiblazer SS).
2006 is the confusing model year since it depends on the vehicle platform (2006 Corvette and CTSV are 58x, 2006 GTO/SSR are 24x).
At the end of our TRG-002 instructions we have a chart that shows the different reluctor wheels by make, model and year vehicle. Click here to see that document.
The 2005 LS2 wiring harness won't work on the 2007 LS2 engine since the 2007 ECM (E38 or E67) won't work on that engine. The ECM connectors are different as is the crankshaft position sensor connector. You could change those connectors but why bother. Get the correct harness for the correct year engine if you are going to go that route.
You are basically trying to control a newer engine with an older ECM (I am assuming you have an ECM to go with that harness). That happens fairly often and is the reason we developed our TRG-002.
Options are:
Options are:
- change the reluctor wheel to a 24x crank reluctor wheel and 1x cam gear and change the crankshaft speed sensor (you can keep the same camshaft position sensor)
- get a different wiring harness and ECM (E38 or E67 based)
- use our TRG-002 to convert the 58x crank/4x cam signal from the 2007 engine to the 24x crank/1x cam signal the 2005 ECM is expecting to see
