Scoggin Dickey LS3 Heads
SD says their LS3/L92 Cylinder Heads are 70 cc, I thought that LS3/L92 heads were 68cc combustion chamber. Anyone know for sure?
http://sdparts.com/category/sdpc-ls3...r-heads?page=1
My guess is that if you measure 10 different heads, you'll find that the cc size varies quite a bit based on a number of factors associated with casting variations and machining differences.
LS1Tech Premium Sponsor
I believe GM's spec on it says 69.xCC's +-1cc...They definitely have a little variance one to the next being cast pieces!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
